Can Anyone post a few pictures of the proper wiring for the hand on a Johnny Mnemonic machine? I am rebuilding the had assembly and I am not sure how some of the wires should be routed. Specifically the wires for the hand travel limit switch. They are currently routed through a small hole that also houses a guide rod for the sie to side motion of the hand. While this does not seem correct, it does look like the original routing of the wires. The only way to change the wiring would be to re-solder them to the limit switch.
Thanks in advance for any help!
