Ok,so I am doing my first real restore.When I got the hulk,everything was working expcept for drop targets and 2 kicker left and right.I noticed the coil on left kicker was wired wrong.When I gutted the whole unit.I had mpu checked and repaired,new driver board,new coils,new power board and all new fuses.When I started it up.It blew the fuse for the 2 kickers and drop targets.When I disconnect the left kicker and replace the fuse.Everuthing else works.As soon as I hook up the left kicker coil.The fuse blows immediately.I tried 3 different coils with same result,2 different driver boards with same result.Am I wrong in thinking,the problem is from the coil to the fuse???? Because if that coil is disconnected the other coils work great and fuse doesn't blow.Now,I did notice a resistor that the coil that keeps messing things up is wired to.Its in last few pics,says RCA.Could this be my problem? When I hook the wire up that comes from that resistor fuse blows
