Game can score either 500 points or 3000 points depending on state of game, like number of drop targets down or number of rollovers. There is a relay marked 500 or 3000, and the schematic shows the same relay (C). At the start of the game, hitting any rollover or any drop target will score both 500 points and 5000 points (not 3000) on the score reels at the same time. This is not correct!
I've traced the circuit but it is a bit confusing within the drop target and rollover sections. There is a switch on the bonus unit that closes, then several possible paths to the 'V' relay, then the 'C' relay, and pulses fron motor 1A to the score reels to score the points.
I suspect there may be a make/break switch in the path that is forcing the incorrect scoring, or a switch on the motor I can't identify. I verified the score reel switches, score relays, C and V relay switches, bonus switch, among others. Also, can't figure how it is suppose to score 3000 points from motor 1A (cam has 5 switch pulses with each 1/3 turn).
Any help with the circuit's scoring path or where to look next is appreciated. I have the schematic.
Thanks, Steve.
