I have a Countdown that I could really use some guidance on (please do not direct me to pin wiki, already been there and need more guidance). I installed a new pascal board and repinned the connectors. The board is firing up and the displays are working. The board shows the standard startup for pascal (I have a genie with a pascal and it looks the same). All the leds light on the board saying all the voyages are there. All the fuses are checked good. The game does not come on, when you press the coin entry or start button the pascal gives a beep boop error tone and says “cannot drive solenoids”. So, I thought maybe the game over or tilt relay but I am not sure how to check them. The ball roll relay seems fine. If not the relay, was thinking maybe a problem with the transformer but also not sure how to verify. Basically need someone who knows system 1 to give me an idea where to look and how to check. All guidance appreciated.
