I would like to replace the knocker coil on my pinbot , the number is 23-800-02, can you please tell me what the 02 means? i found a 23-800-03 at marco , is this the right coil? thank you for your help
Here's some great info:
https://www.flippers.com/coil-resistance.html
also.. http://www.pinballmedic.net/
faz
The last two numbers indicate whether there's a diode or not. If you buy one without a diode--and if your game calls for one, you may have to add the diode yourself (observe the correct polarity when installing--or you'll blow fuse).
This page was printed from https://pinside.com/pinball/forum/topic/need-help-with-coil-numbers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
