Hello,
Does anyone have a Bally Truck Stop? I could use some assistance and pictures would be great as I just purchased this machine and it requires some repair.
1. Does this machine have a back glass or Translite?
Mine only has a translite and no glass backglass (as it must have shattered). Is this correct?
There are two banks of 3 targets in the middle of the playfield. Each bank has one target that is on its own (upper most target) whereas the remaining two are wired together (at least it seems that way). The upper most target works and scores correctly when hot by the ball, whereas the two bottom most targets do not register anything when hit by the ball.
I looked at the end of stroke switch and I believe the problem is not the CPU / MPU but the way the switches are wired.
I am attaching pictures of the the two now working targets and how the EOS switches are currently wired.
I do not have a manual, and the one available at ipdb.org is a very poor scan that is difficult to read.
Does anyone have a Truck Stop for which they can check the wiring for me? Or a better manual that I can review?
Or does anyone know how to fix this problem?
Any advice / assistance would be greatly appreciated.
Mark
