Pretty rare for Mike not having one. He's like 90% on low production machines for me
that others didn't have..
Some Uniteds from the era of your machine has the Bank Relay Coil's circuitry going through
a (sometimes certain frame) Blow Relay so the score motor will cycle more than once
in order to add the pins that were made multiple (double, triple, ect.) times. That determines
on what frame it's on, but from looking at the backglass, I figured your machine didn't have
a Blow Relay. Other than that, the Bank Relay's coil energizes through the switch off of the
Score Motor's cam. And yes, it's understandable the pins would reset twice, but seems like it
would add the score twice also since the Bank hasn't reset the Relays made. Has to be something
more to it. The thing is, I work on many other EMs (especially come Winter) than bowlers, so even
if I once had a Mercury, I probably wouldn't remember 100% of its function..
I remember having a machine that had a 5th Frame Blow Relay, so I guess a 3rd Frame Relay
is possible, but not seeing a need for one on your machine. I'm afraid, without having the machine
at my presence, I'm not sure what's causing that. At least the score is registering accurately, so for now,
maybe you should go back to the 100s reel not flipping. If you had someone rather local that could
help out and do some jumping to locate where it's loosing that connection, that would probably be
a big plus, but for now, I'd recheck the wires on the Player Unit, and maybe even carefully checking on the
backside of its wiper board..
