The coils each are made up of two separate windings.
You should be able to measure the resistance between the common lug and outer lugs to determine which one is which on both coils.
Then just apply the wiring to the replacement coil similar to the existing coil between the red, end of stroke switch, and off-white.
This page was printed from https://pinside.com/pinball/forum/topic/need-help-wiring-a-flipper-on-a-big-valley-german-verizon- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
