Hey folks, I’m a n00b to tinkering / repairing pinball machines, but am willing and wanting to learn! I’ll admit it, electrical stuff has never really been my favorite thing in the world, but I’ve still had some real-world experience with it (some examples: wiring up assorted new lighting modifications in my car; installing & wiring heated seats; wiring/connecting my garage door opener (SS board) to a dashboard switch; etc. All of these involved basic electrical work & soldering.) While these pin machines certainly look complex, I refuse to be intimidated by them! Naturally, though, I’m going to need a little help as I learn -- and so it begins. Here’s my current situation, in both TL;DR and long detailed versions. Pics at the end -- please have a look at these too.
TL;DR version:
- Bally 1977 Bobby Orr Power Play
- Per prior owner: Used to work fine with regular play, then used irregularly, now doesn’t work.
- Symptoms: Some lights, no scoreboards, no play start
- Found burn around resistor on Solenoid/Voltage Regulator board
- R&R’d resistor
- Also connected two unconnected ground wires elsewhere on machine
- Powered on: No noticeable change to condition/state.
- Found broken wire on knocker solenoid
- Resoldered wire
- Powered on: blew fuse F4; no other noticeable change to condition/state.
- Awaiting new fuses & knocker solenoid (intend to R&R)
- Looking for feedback/tips/tricks on further troubleshooting
Here’s the longer, more detailed version:
I recently bought two machines; one (EM) works fine, and the other (SS) needs some (hopefully) minor work.
This is a ~1977 Bobby Orr Power Play from Bally. The previous owner states the machine played perfectly fine while it was being actively used. Then, in a move/separation situation (~2 years ago), the machine was left behind and sat, rarely used. Its health was not monitored by the enthusiast/owner.
Recently, in preparation to sell it, the owner went back to evaluate the machine, turned on to play/test; he found some lights didn’t come on, the scoreboards didn’t activate, and the game wouldn’t start. He took a peek inside and identified a burned area on the solenoid/voltage regulator board. He pointed this out to me, and said he didn’t remember that being there, so it could be the culprit. The burn was around a 330 ohm resistor; I unsoldered and removed it, and soldered up new resistor (well, a 10, 100, & 220 in series) in its place.
Pic of board (overall):
Close-up of burn area:
Back side of board, in burn area:
While working on this, I also remembered he pointed out two ground wires that were not connected. One I could tell exactly where it was supposed to be connected, so I connected it. The other, I was uncertain, so I connected it to the perforated metal inside cabinet ‘throat’. This seemed like where it might go, as it appeared to be at the right length. (I do intend to follow up on this to see if there’s anywhere else it may have been intended to terminate.)
Where I connected one grounding cable coming up out of the lower cabinet. (Pic taken before I connected it.) You can see the perforated metal plate also, where I then attached the other grounding cable.
So … after replacing the resistor and connecting the ground cables, I turned on machine and …… similar state. Mostly lit, no scoreboards, no game start. (It seemed like there may have been more lights on than before, but might’ve been my imagination trying to be hopeful.)
I looked around for anything else that seemed amiss … and I found a broken wire for the knocker solenoid (backbox, upper left corner) hanging out in space; the end of the wire looks like it tore off the terminal. I re-soldered the wire’s end to the terminal on the solenoid.
Pic of this solenoid, after I resoldered the yellow wire.
I then powered on the machine again – this time, it blew out fuse F4. Otherwise it stayed in the same state as before.
Looking around for repair tips, I found a handy reference for Bally machines that read “If fuse F4 blows, there is either a problem with the backbox knocker, or the cabinet coin door lockout coil, the solenoid bridge rectifier (on the rectifier board), or the rectifier board's varister.”
Pic of rectifier board (after I blew fuse F4):
This seemed like too much of a coincidence, that I’d just rewired that knocker solenoid and then blew that fuse ….. so I’m going to replace that solenoid also. I’ve got fuses and the solenoid on order; awaiting delivery.
In the meantime, while I wait for my new parts, I’ll probably try some of the basic voltage testing listed here: http://techniek.flipperwinkel.nl/ballyss/rep/index1.htm#minimum Aside from this (or any of the detailed overhaul work describe at that link) does anyone have particular ideas/suggestions? I’m worried the issue with the burn on the solenoid/voltage regulator board may not be resolved, so some hints over there would be great.
Many thanks in advance, for the help you're about to provide, and for all the help you'll provide in the future. I look forward to 'giving back' down the road, however I can, after I get proficient at this stuff.
