I have a Stern Pirates of the Caribbean machine that I am working on and I need to replace the connector that runs from the power box to the transformer. The power box was totally missing and I have a new one but I don't have the connector wire. The transformer has a 9 pin (3x3) connector with a locking tab on one side and slightly rounded corners inside in two corners. But I am not sure what connector fits into it? I am attaching a couple of photos.
Also, can a PotC owner help me identify which pin is pin 1 (black wire lead) and 7 (white wire lead)? maybe what wire colors they connect to? The wiring schematics in the manual are easy enough to understand (pin 1= black or Hot, pin 2 and 3 jumped together, pin 7 = white or Neutral, pin 8 and 9 jumped) but they don't list the wire colors of the transformer connector. I would like to be positive which pin in the transformer connector is pin 1 and 7 so I align the new one correctly.
Is 18 gauge wire the proper wire to use here or should it be something else (14 gauge)?
I appreciate all the help!
