I'm working on my radical, I was adding in the left VUK and accidentally wired the coil wire to the wrong wire in the auxiliary diode board, it Blew the transistor , pre driver, and 7408 for the shooter Kickout. The transistor, pre driver and 7402 blew for the bottom popbumper as well in an unrelated matter.
The displays were working after the fact.
I then replaced the components, triple checked all of my work, even socketed the ic's.
Now my displays are not coming on at all. And the "blanking" led is not coming on .
I checked all of my fuses (pulled them to check them) they are all good
Any help or ideas?
