(Topic ID: 171915)
Need help on ToM
By chuckcasey
  • 9 posts
  • 6 Pinsiders participating
  • Latest reply 4 years ago by pintechev
#1 4 years ago
I picked up a very nice Threatre of Magic and nearly finished going through and tuning it up.
I need help with a few ToM things....
1. On start up "Check Switch #87 Left Lane Exit". Which switch is Left lane Exit?
2. Is it normal when I have a ball in vanish and shoot second ball around outer orbit (right) it gives me the vanish ball too (like a two ball multi-ball)??
3. When I shoot a ball in to the basement sometimes it does not register. I have tested the switch and it's intermittent. Is this a common issue?
4. When ejecting balls from the basement frequently the basement door opens then closes and then opens and ejects ball.
5. Basement door is VERY squeaky. Normal?
I'm so friggin' glad I picked up this Theatre of Magic. It's my wife and daughter's fave game. I scored big on this one.
Thanks for all your expert help.
#2 4 years ago
Quoted from chuckcasey:
Look at the playfield switch diagram in the manual. The switch wire could be stuck against a side of the slot hole.
Check all the solder connections. Check the header pins for the switch...they could be dirty and cause intermittent issues.
#3 4 years ago
It's the switch all the way over on the left that says "exit" above the switch. Go into switch test and manually test the switch and see if it works.
Yes it's a 2 ball multiball. Shoot for the captive ball
Probably a flaky switch, check the switch in switch test manually and see what it does
Do the same with question #4
Yeah they all are a bit squeaky lol
Congrats on theatre it's a killer game I just picked up one again recently also
#4 4 years ago
Thanks guys.
I have tested the basement switch in test. It's intermittent. I'll do more test tonight. Sounds like its specifically not a normal issue ToM.
Switch #87 sounds like the "EXIT" lane but its not. I will check again. I understand what you mean about being "stuck" - I'll keep hunting for the switch and expect it to be shut.
There were a half dozen other switches and stuff that needed adjustment. maybe I over adjusted one of them.
Love the game when my wife lets me play.
#5 4 years ago
Page 2-43 in the manual:
#6 4 years ago
BINGO !! Thanks zaza. You put me on easy street. I really need to get use to this pin. It's my first Bally's.
#7 4 years ago
It's my first Bally.
Soon there will be many more.
#8 4 years ago
Okay, easy peasy fixing #87 tonight.
The basement still is not sensing the ball when dropped into the basement. Ball goes in, ToM goes in to a find ball cycle three times and finally on the forth try kicks a ball out. When using the switch test, the basement switch consistently works after a small adjustment. It all most feels like the basement door opens but the ball eject doesn't trigger.
#9 4 years ago
Replace the switches. It's cheap and they shouldn't need continuous adjustment to function.
