Quoted from andystirn:I unplugged ribbon cables to v8motor control and and plugged back in
With power on ?
If not. Be sure red stripe pin one each end and not off by a row.
Quoted from steveh3:but is this fuse good?
Gee. Hard to tell. Pull it and check with a meter to be sure. Looks can be deceiving.
Make sure that the connectors are all on right. You may have bent a pin or missed a row or something. I have done it also
Quoted from LTG:Gee. Hard to tell. Pull it and check with a meter to be sure. Looks can be deceiving.
Absolutely should check with a meter. When compared to the fuses above it, it looks like it's blown and may have been the original reason for the game not working correctly or for the balls not coming out now. The ribbon cable might also be nicked and when it was removed and reinstalled, it could have shorted out something. I just made an observation for Andy to look at. Might be nothing, but certainly worth looking at.
This page was printed from https://pinside.com/pinball/forum/topic/need-help-just-purchased-a-corvette-machine- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
