Right up front I should say that I don't have experience with pinball machines, but I have been reading some things about EM machines, and I have a fair amount of electrical knowledge (don't let the user name fool you).
I have a Gottlieb Scuba machine that I'm trying to get working. It seems like it's close to functioning, it just never seems to start a game. Both the playfield and backglass light up when I plug it in. When I press the start button, both the scoring motor and the player unit go through a cycle that lasts about five seconds. There is a youtube video titled "Gottlieb pinball reset sequence animation", and what's happening looks very much like what that video shows (can't link to it with so few posts on this forum.) During this time, the ball in play display cycles through its range of 1 through 5, and the score reels will reset to zero if I had manually set them to something other than zero. It should be noted that the game over light stays on continuously while all of this is going on.
But after this cycle ends, I'm basically back to where I started. No ball in play numbers are lit up, just game over. The flippers don't respond, and neither do any of the bumpers. If I manually trip the far right coin switch, the scoring motor seems to go through a shorter cycle, maybe only 1/3 of a turn. Three credits also get added to the credit wheel, but the machine still doesn't act like a game is in progress. If I push the start button again, it just goes through the same cycle I described before, and the credit display decreases by one.
I thought maybe the game was in the tilt mode, but if manually trip the tilt switch, I can definitely see the tilt relay energize, and all the playfield lights shut off (this persists even if I unplug the machine, until I hit the start button again and the machine goes through the whole cycle again.)
The only other odd thing I noticed is that if I trip the far left coin switch (there isn't even a coin slot installed here) the machine seems to go through the same cycle as if I pressed the start button. None of the coin switches appear to be stuck on. All relays along the right side of the lower panel seem to move freely.
Any ideas? It just never seems to start a game. I do have the schematic for this machine, so that's good.
Thanks.
