So when I launch a ball in High Speed, 99 times out of 100, it hits the right side of the ramp and won't go up. I've read a few threads about adjusting the launcher (Three screws on the back of it.) It's definitely off a bit and not hitting the ball dead center. No matter how I adjust those, it doesn't move. The front of the launcher screws on to the back with a plate. I could put a washer or two on the front of the launcher, but you'll then have a gap between it and the front of the machine. Putting washers on the inside won't help because of how it mounts to the plate.
Then I found that there's two screws under the don't drink and drive plastic. I messed with that, but I don't see how to adjust it. There's a slot for one screw (Seemingly to adjust it), but not the other. Do I need to remove and open up the other hole so it's slightly slotted?
And the few times it does hit the ramp, the clear plastic over top of the ramp must have deformed over time and has dropped in to the ramp. So most times, the ball jams in between the plastic cover and the ramp - stops and comes back down. Thinking I need to heat that slightly and try to bend it back out.
Doesn't seem like the ramp itself can be adjusted? So the launcher and the release ramp is where I need to be I assume.
Here's a video in slow-mo showing the miss (And how far off it is!)
Here's a picture detailing what I'm seeing on the launch ramp. See the two screws in red. Left screw is slotted, right screw is not - so that's useless. I did loosen both and tried to move the ramp left as much as possible, but no difference.
