I have a vacation America and the power supply mini board has fuses on it. Having a problem understanding if I need to use all slo blo fuses on the 4 fuses on power supply or use fast flow.
The book says only use a slow blow for the upper on off switch fuse, DONE .
The books says only replace the others fuses by properly rated fuses. But book did not say use “ SLO BLO” or NOT ?
My question is do I use slo blo and follow the rates on other fuses. Or just use basic fuse.
