Need inner/outer and length. Thanks in advance. Mike Paris
Stroke of luck. I found a swep1 lightsaber tube that I could measure. It is:
1" OD (outside diameter)
7/8" ID (inside diameter)
16th of an inch thick
Approximately 2'4" long (I couldn't take the assembly apart to get the exact length but this is close enough).
I'm going to buy a clear piece of polycarbonate tube with the above specs and try the dark green RIT dye on it. Unless there is another suggestion.
http://www.amazon.com/Polycarbonate-Tubing-Wall-Clear-Color/dp/B000OM9IO8
This page was printed from https://pinside.com/pinball/forum/topic/need-dimensions-of-star-wars-lightsaber-neon-cover and we tried optimising it for printing. Some page elements may have been deliberately hidden.
