One thing I would love to know is the lead pitch for the radial capacitors.
Original caps had a specific spacing between the two pins and specific diameter of the cap.
Over the years, capacitors have gotten smaller. As they get smaller - the lead pitch (spacing between pins) often gets smaller. Normally I go up in voltage rating to get closer to the original pin spacing.
For example -- the 1000uF, radial cap at C1. If I supply a new 1000uF, 25V capacitor with the same capacitance and voltage rating - chances are it will not fit properly. I may have to recommend the 63V version just to get the pin spacing right so that the cap will fit properly.
Is there anybody out there that can get the lead spacing for C1, C2, C3 and C7?
Normal lead pitch dimensions are: 2mm, 2.5mm, 3.5mm, 5mm, 7.5mm, 10mm and 12.5mm.
From there - I can recommend US or Japanese brand capacitors by part number.
Ed (GPE)
