(Topic ID: 207539)
Need Bally Ball Lift Motor Assy
By minnesota13
6 years ago
  • 10 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by BingoButch
#1 6 years ago
I need a Bally ball lift motor assy. The motor works fine, it pulls in but the gear box is shot - motor runs but no gearing.
This is for a Bally Show Time. It may not be worth replacing the ball lift, but the machine is "apparently" working -- or perhaps starting to work.
I just started on this one.
#4 6 years ago
You need everything but the motor right ? So just the gear box right ? Take a.pic and so me exactly what you need have a 5000 Sq ft building with parts
#5 6 years ago
Thanks Butch. It turns out I was able to repair my old gear box.
I disassembled my ball lift gear box by drilling out the rivets and found the old grease had turned to glue. I cleaned it up re-greased and reassembled using small screws. I had to drill out the rivet holes a small amount to fit the screws. It is now working OK.
Knowing I could find a replacement ball lift gear box shored up my confidence to take it apart. usually all the gears fall out and it becomes a puzzle to how the gears were originally placed. This unit is on the simple side so isn't wasn't too difficult to
reassemble correctly.
It is good to know there are resources for bingo machine parts. Thank you.
Now to determine why the ball lifter continues to feed all the balls.
#6 6 years ago
Quoted from minnesota13:
assuming ball lift cam switch #1 is not stuck closed or shorted (lifter will run with no balls in the game), you need the lifter start relay to power to stop the ball lift motor. The naming of the lifter start relay is kinda backwards for historical reasons.
the ball runway switch in front of the shooter powers the lifter start relay, and the ball gate switch at the top of the runway unpowers the lifter start relay.
if you have the playfield tipped up against the head and the balls start lifting and dumping down into the cabinet, push the runway switch closed with your finger to stop the lifter from raising another ball.
#7 6 years ago
Yes, it was the shooter lane switch that needed to be actuated to stop the balls from continuing to feed. Thanks!
#8 6 years ago
Anytime. . Have almost every bally part.you will ever need. And I'm glad.your up and running a lot of very nice and experienced techs on here to help
1 year later
#9 5 years ago
Hi butch. Got a replacement belt for a bally lucky alley by chance?
This page was printed from https://pinside.com/pinball/forum/topic/need-bally-ball-lift-motor-assy and we tried optimising it for printing. Some page elements may have been deliberately hidden.
