(Topic ID: 248152)
Need Alien Poker Plastic Drop Target part(s)
By CUJO
  • 17 posts
  • 6 Pinsiders participating
  • Latest reply 4 years ago by CUJO
#1 4 years ago
Where can I find these plastic miniPCB supports that the post have gotten brittle and cracked/cracking off. They're like 38+ years old!
I super glued two of them but just would like to replace with new since it's apart and don't want more to break off. They are delicate.
#2 4 years ago
There's a model floating around so you can 3d print them. Works pretty well
#3 4 years ago
Not available new. Used parts only....
Make sure you do not overtighten the bar across the back, that helps to crack the bosses (and makes your targets drop slowly, if at all/adds bricking)
If they are available new hopefully someone will post as I'd like to pick some up too.
#4 4 years ago
Quoted from slochar:
Well I've gotten the two posts super glued back on but I'd like to rebuild it stronger for sure with new or better plastics.
Doesn't any other game use these like Firepower or that era?
#5 4 years ago
Huh, two threads on this part in an hour, was getting me confused....
Anyway, they're not a fast part to print, so the price is more than I'd like, but I do offer them on the website. I did have to tweak the design a bit to print reliably due to the overhangs. It's also a bit more stable now, less twisting on the bracket.
http://www.siegecraft.us/presta/index.php?id_product=79&controller=product&id_lang=1
#6 4 years ago
Quoted from HHaase:
My bad. Made the other thread. then did a search and found one already started.
#7 4 years ago
Quoted from CUJO:
Yes, all WMS drop banks have these from that era, system 3-7 for sure. Lots of Pokerinos can be parted out to get these.
#8 4 years ago
A fragile design too. Not much you can do about the thin standoff sections, can’t make ‘em thicker because they need to fit between the targets and hold the right size screws. And the tall spindly design limits the materials you can reliably print with on an FDM machine.
I’m actually printing an order for 10 of these right now. I just wish I could get them to print faster so I could drop the price. I know people need em but also need em to be cheaper. Hopefully when I jump to a resin printer I can work on the price problem.
#9 4 years ago
I see a user named PBJ on the Arcade Forum has made these for his AP. They look good!
Anybody know of the most "reasonable" place to buy 6 of these as 3D printed or NOS?
https://www.thingiverse.com/thing:2792174
#10 4 years ago
Quoted from CUJO:
Sent you a PM.
#11 4 years ago
Quoted from Yelobird:
Sent you a PM.
Thank you.
#12 4 years ago
Quoted from HHaase:
Curious how long it takes to print one?
What material are you printing them in now?
#13 4 years ago
About 2 hours in PLA. I found PET to be too stringy and doesn't adhere well on my print bed, never had much luck with nylon. ABS just turns into a slumped mess on the screw extensions. I know PLA probably isn't optimal either, as it's a bit on the brittle side, but the shape just needs something that doesn't deform at print temps on thin sections.
Saving up for an SLA printer which will change things dramatically..... but that's months away until I have the money and the one I want is available.
-Hans
#14 4 years ago
Quoted from CUJO:
Parts like this need to be at minimum PET. I prefer and typically print mechanical parts like this in ABS or Nylon which is fairly simple and strong as original for the most part. I reserve PLA for cosmetic parts that have no function as they rarely last.
#15 4 years ago
Completely agree, and most of my stuff I do PET these days as well. I've almost given up on ABS completely now except for lamp shields.
This particular part I've been running in my Black Knight for the past 4-5 months now without any failures, despite being PLA.
-Hans
#16 4 years ago
I had a tech try installing the thingaverse improved spacers and they just didn't work right in Alien Poker.
Melted some of the pteg and welded the old ones.
#17 4 years ago
Quoted from BMHouze:
Well that news is disheartening...
Playfield - Plastics
The Pinball Scientist
$ 100.00
Tools
Pincoder Store
$ 12.50
RoyGBev Pinball
$ 42.95
$ 27.95
3,100 (Firm)
Evansville, IN
NO GOUGE PINBALL™
