New! Dark mode!
(Topic ID: 279119)
Need Advice; Gottlieb System 1 Boards for Sinbad
By jrobinson90
11 days ago
  • 15 posts
  • 13 Pinsiders participating
  • Latest reply 1 day ago by gjm
#1 11 days ago
I picked up a Sinbad SS recently for fairly cheap. Fixed it up a bit to get all the playfield components working, and playable at times, but there seems to be a few issues that I think are being caused by the boards, particularly coils in the chime box and out hole kicker staying active and heating up. It functions varying on days it wants to. I noticed the wires to the boards have been soldered directly to the MPU and driver boards. The only thing I can think of doing for a fix is buying new boards and edge connectors. The MPU has some battery corrosion and two wires fell off as a result. There is also a bad looking transistor on the driver board. I looked into the boards made by Ni-Wumpf and edge connectors from Docent Electronics, the cost seems to be just under $500. I really like Sinbad, but am hesitant to put this money into the machine, and also hate the idea of this just being a parts machine. Is there a cheaper way to fix this up?
#2 11 days ago
Get molex connectors first between the MPU and driver board and go from there
Don't make it a parts pin. Sinbad is a GREAT game
#3 11 days ago
Quoted from jrobinson90:
If you have (basic) soldering skills try LISY1 as a replacement for your MPU https://lisy.dev/lisy1.html
In any case desolder that old 'Datasentry' Batterie as fast as possible.
The leakage of that Battery will things make even worse.
#4 11 days ago
Pascal all-in-one board will cost you $350 or so. That's the route I would go.
#5 11 days ago
Pascal is the only way to go.
#6 11 days ago
I second that.
#7 11 days ago
Could be a grounding problem between the boards. Suggest soldering seperate
ground and 5v wires between boards and supply. Also make sure the 5v supply
is close to that value.
Sounds like your boards are working, just a poor connection between them.
#8 11 days ago
That playfield looks great. Save it.
I also am a big fan of the Pascal all in one board. Eliminates the interconnect, but you still need to remake a few edge connectors.
#9 11 days ago
Quoted from Friengineer:
Here's the link:
https://www.flippp.fr/pi1x4.php
#10 10 days ago
It sounds like one of the unobtainium spider chips on the cpu board is failing. No choice but to get a replacement board.
All those wires soldered to the boards is considered a hack and should be removed. You will need to get the correct edge connectors and pins from Great Plains Electronics. Then, any replacement boards you get will be unpluggable just like the original boards were.
#11 8 days ago
Quoted from bontango:
Have had an excellent experience reviving games with the Lisy boards and they are easy and fun to build. Saved a Charlie's Angels last year which had no head (cabinet and playfield only) with a Lisy1 and buying a head and other boards from eBay and local pinball friends.
Have also successfully used Lisy80 and Lisy35 with friend's games. These are my go-to boards when debugging a game with a broken MPU because switch matrix, solenoid and lamp testing is all supported through the web interface. They do take ~30 seconds to boot though.
I find reviving system 1 MPUs is a futile waste of time - Lisy1, Ni-Wumpf and likely anything else will be more reliable . Anyway, Sinbad is a great game, is deserves to be saved and enjoyed!
#12 8 days ago
Hey son, don't be so cheap. Just buy the Pascal board and be done with it. Just kidding, I know you're a starving college student. Good luck with your first project machine.
#13 2 days ago
Anyone looking for a "Sinbad" project pin? If so, PM me.
#14 2 days ago
Quoted from gjm:
Well yeah, but where are you?????
#15 1 day ago
Quoted from zarco:
Myrtle Beach,SC
I might have a block on that in my settings, I will look into it later, thanks for letting me know. If you want more info please PM me so we don't tie up the guys thread
325 (OBO)
Myrtle Beach, SC
$ 49.00
$ 289.00
$ 400.00
Great American Pinball
$ 68.00
$ 239.99
PinballBulbs
Hardware
$ 28.50
$ 19.95
SilverBall Designs
PinCoasters
Professor Pinball
$ 9.99
Bent Mods
$ 26.95
$ 25.50
$ 48.00
$ 21.00
$ 225.00
Cabinet - (Alt) Translites
FlyLand Designs
$ 54.99
$ 36.99
$ 5.00
Metal-Mods
$ 50.00
$ 42.00
The MOD Couple
