(Topic ID: 323905)
need advice buying non working pinball
By OTCHU
5 months ago
  • 74 posts
  • 34 Pinsiders participating
  • Latest reply 5 months ago by RyanStl
There are 74 posts in this topic. You are on page 1 of 2.
#1 5 months ago
hello everybody .... so this coming Sunday, I am going to take a look to buy maybe a Maverick pinball ... The woman told me that does turn ON but flippers are not working and not sure the DMD is turning ON .... She is asking $3000 for it but of course that will not happen .... what you guys think about a decent price ??? looks like the playfield is in a good shape and the cabinet except fading color on 1 side
#2 5 months ago
Wayyyy to vague my friend
Does it have missing boards? That dmd is expensive. I’d pass unless you really like the theme/have money to spend/have time to fix
#3 5 months ago
Can you do any work necessary yourself ? If not run away.
#4 5 months ago
You'd have to figure out what needs fixing to understand what kind of discount would be appropriate. Unless you're an expert at repairing machines, that seems like an unlikely outcome before you actually buy the machine, so you have to expect the worst.
Given the description you've provided so far, could be anything from a single loose wire to a whole board missing or in need of replacing, maybe multiple boards and parts (though in my experience that doesn't usually happen because once one thing breaks, the machine winds up going offline so nothing else gets a chance to break). Someone trying to sell an inoperative machine, and especially if they themselves don't know what's wrong with it, has to accept that they're going to get only a fraction of the market value for the machine, assuming they can sell it at all, because you could spend an enormous amount of time and money getting it back into playable shape.
Her best bet would be to get the machine fixed first and then sell it. If she is worried it would cost more to fix than she'd get back selling it, then she ought to sell it at a price appropriate for the working parts only.
#5 5 months ago
here the pictures she sent me .... I have 4 pinballs myself and did fix 2 of them (lethal weapon3 and Last Action hero) .... I was thinking about $1400 ... something like that
#6 5 months ago
$3,000 is a good price if it’s working 100%
#7 5 months ago
but its not working at 100% ... flippers are not working and looks like the dmd is not power up
#8 5 months ago
Bad power supply and corroded boards due to leaking batteries?
#9 5 months ago
I think your offer is a good one based on the issues. I also agree that 3K is decent if it were fully functioning. I passed on a non working Maverick for $500 but this was long ago when I wasn't confident in my repair skills.
#10 5 months ago
A good rule of thumb is to make a quick shopping list based on the worst case scenario, then subtract the value of that list + something for your time from the going rate of a functional game in similar physical condition.
- It most likely hasn't been shopped in a long time. At the very least, you'll need a set of rubbers and a flipper rebuild kit.
- If the flippers aren't flipping, although it could simply be a blown fuse, it may very well need a new flipper board.
- The display is not working and the original Sega large DMDs are very hard to come by. Because of this, you may as well upgrade to a ColorDMD.
- As mentioned above, the MPU could be in great shape, but it's possible (and more likely) that it has suffered alkaline damage. The DE/Sega power supplies are known to have issues, as well, so you can add one of those.
As you can see, it can add up pretty quickly. Keep in mind this is also just to get the game running as intended, never mind extras like LEDs. It's entirely possible that you bring it home, swap some fuses, and she'll fire right up, but keeping the worst case scenario in mind can really save you some $.
#11 5 months ago
For her to ask $3000 leads me to believe that she's on pinside.
#12 5 months ago
Quoted from OTCHU:
Pics show general illumination lights on, but no feature lights lit (some should be lit in attract mode) and dark display. That's a good indication that the CPU board isn't booting properly and likely more than the flippers and display aren't working. Could be bad power supply, could be destroyed CPU board due to battery leakage, could be something else. You shouldn't have an figure in mind until you inspect the game. I would also suggest researching replacement displays as that's a large one and replacement options may be limited. Even if factory display is working, it's very old and will eventually need to be replaced.
#13 5 months ago
Quoted from Spiderpin:
$3K didn't come out of thin air. Pinside average is $2800. She thinks she has something that she clearly doesn't. But to land on that number means research was done, and if she can get that far, you can also instruct her how to open the backbox and get you some board pics so you don't go driving all that way to check out what may be a lemon.
#14 5 months ago
Maverick is a fun machine. Mine was very reliable and only had minor problems that were not expensive to fix. I doubt the display is shot. The connectors get flakey and there is a service bulletin that is easy to fix it. The power supply board was easy to work on. I replaced a few caps and a bridge rectifier and fuse. All cheap. The machine seemed very solid to me. She needs to lower her price in half and show you photos so you can check for leaky batteries or damaged/missing boards.
#15 5 months ago
A working Maverick 2 years ago was a sub-$2000 pin. $3000 and it's dead? No thanks, someone has been trolling Ebay for pricing.
I'd not pay more than $1000 for this example. You might get lucky and its just a burned connector or it's a smoked CPU with battery damage. You will drop $300 to $400 for a replacement board and that is just the start depending on what else you find.
$1300 to $1400 is a reasonable offer.
#16 5 months ago
Quoted from OTCHU:
1,000 tops.
#17 5 months ago
Or Ebay
#18 5 months ago
Quoted from OTCHU:
If you think she will take less than half of her asking then more power to you and go get it!
#19 5 months ago
As others said - it is behaving as though it could have a battery leak.
If you are local then consider going over there and showing her the leaking batteries on the MPU. Then offer her a price accordingly. Make sure you confirm whether or not replacement MPUs are available for that game and what the cost is.
Also look very carefully at where the battery leak spread to (connectors below etc). Collateral damage could be time consuming or expensive.
#20 5 months ago
Before you go, if you go, ask if she has the keys.
#21 5 months ago
Quoted from Lermods:
Yeah I love that. Two times now. Did end up more than satisfied regardless…
#22 5 months ago
Quoted from brainmegaphone:
I would not waste my time. Why provide diagnostic help for nothing which very well could backfire in your face.
Simply state the price is unreasonable for a dead machine, make her an offer based on the most likely scenario they are commonly known for and here is my number. And wait.
#23 5 months ago
An American pickers episode?
#24 5 months ago
You're going to have a hard time getting her down to 1400 if her asking price is 3k. 1400 is probably what it's worth considering the most likely scenario is that the MPU has damage or is toast due to batteries leaking. But she has been on Ebay or talked to some expert that told her "what she has" and she will not want somebody to come along and cheat her out of her valuable collectable. If it's close, I would go look, but don't get your hopes up. If it's more than an hour, I would tell her a price range you might offer depending on what you find when you get there and see if she is receptive. Otherwise, you will waste your whole afternoon on a turd hunt.
#25 5 months ago
She is living like 15mn 20mn from me ... going to see it tomorrow
#26 5 months ago
Well hope u get it. I've been surprised more than once how people can be more receptive once you point out the problems and repair/replace costs.
#27 5 months ago
Quoted from gdonovan:
To be clear I would have shown her it in the context of why I was offering X dollars for the game. It takes approximately 2 minutes to get to the backbox so if he wants the game at a fair price then I would so as I recommend.
I'll admit, however, that I don't try to buy pins like this. The risk/reward of my time wasted just doesn't work for my life (work schedule, family, etc). So I don't have a lot of experience trying to talk someone down from $3k when the game is trashed. I imagine such an effort is hit or miss.
#28 5 months ago
Not to mention the lower cabinet is really faded and it has the wrong legs on it. Dirty, not working.......your opening up a can of worms. Good luck getting here down to the $1000 mark. That's a great game but not for her price and condition. Let us know what happens.
John
#29 5 months ago
Anything you point out to her "might fix it" she will just tell the next buyer "it's worth X and only needs Y for it to work" because some pinball guy told me so. You explaining it may have other issues or need to be shopped will just sail overhead.
Simply state the price is unreasonable for a dead machine, make her an offer and here is my number.
Trust me, been in your shoes. People who think they have a 3k goldmine are rarely budged aside from time, when they finally realize they are wrong or pressed for time/money.
I have a hard rule now never poke at the dead machine while on site, had one seller raise the price $1000 because I spotted what was wrong with it.
Never again. Wrap, load and leave.
#30 5 months ago
Well .. I passed for the show tomorrow ... she texted me to say somebody else coming tomorrow afternoon, so if I want it, I need to be there and take it by 8am .... and she is leaving for work at 9am ... hate to be rush like that without knowing what is going on about the pinball ... can't afford to do a $1500 - $2000 mistake
#31 5 months ago
Quoted from OTCHU:
She’s probably full of shit. Good chance you hear from her in a week or so.
#33 5 months ago
Quoted from OTCHU:
I call shenanigans…and Tomfoolery.
#34 5 months ago
Quoted from CrazyLevi:
Exactly so.
Oldest trick in the book.
Simply reply, you have my offer... cash.
The word "cash" is magic on some people, it will prey on her mind. You can always counter you are going to look at another pin in a few days... only have cash for one though.
11
#35 5 months ago
ACT II : she text me this morning to say the guy will not show up so I am welcome to come get it ..... I said, let me take a look this afternoon and if I take it that will be for sure no more than $1500 maybe less depend of it ..... she said ok no problem !! So we will see guys !!!
#36 5 months ago
#37 5 months ago
Good luck. As mentioned, hopefully she has the keys
#38 5 months ago
She said she does have the keys
#39 5 months ago
Quoted from OTCHU:
Remember; just look, say nothing, pay, wrap and leave.
#40 5 months ago
Because we live in Florida check for bugs (termites) and water damage!
#41 5 months ago
Fuses all good ... main board doesn't boot. No sound. No Dmd. 12v 5v -12v there ... playfied is ok .. need a deep clean .. most Rubber are falling apart... I offer her $1200. She did not take it
#42 5 months ago
I thin my that’s a fair offer considering other things wrong you find down the road.
I bet she may call you to come get it after a few days. Good luck!
#43 5 months ago
Quoted from OTCHU:
You did diag onsite?
#44 5 months ago
Did she say why she wants to sell? Give her a call at the end of the week to see if she changed her mind. Who knows you might get lucky.
#45 5 months ago
Quoted from pyrotech:
I vote not to call. If she changes her mind, she'll call you. Calling just gives her the impression that you're more interested than you really are.
#46 5 months ago
That has hurt me many more times than it has helped me…
#47 5 months ago
Quoted from OTCHU:
Quoted from OTCHU:
She probably already expected you to say "I'll take it for the $1500".
If you examined the MPU and did not see any battery damage, $1500 would have been a good project price.
#48 5 months ago
If you throw a number out (like 1500) ...that's all they hear.
I am late to the party here, but I would've offered 1000. That pin needs a lot of love. You will have to source and purchase several high dollar parts, and either have the knowledge to fix it (which will chew up time) or pay someone handsomely to do it.
I would hold fast at 1200. I think that's the top of the mark for it. You may also want to reach back out to her in a week or two. It couldn't hurt.
#49 5 months ago
Quoted from Daditude:
I don't think these are current prices you are going with; with $1,000. Kind of older thinking on project prices.
#50 5 months ago
If it's worth 1200, it's worth 1500. If it's not worth 1500, it's not worth 1200.
$ 21.00
$ 54.99
Shooter rods
Professor Pinball
Interactive
Men
PinSound
$ 18.95
Gweem's Mods
Sound/Speakers
3,900 (OBO)
Richmond, VA
$ 27.95
$ 60.00
Maverick Reproductions
Toys/Add-ons
$ 22.50
Decals
$ 54.99
Shooter rods
3,500 (Firm)
Charles Town, WV
$ 5.95
The Pinball Scientist
Protection
This page was printed from https://pinside.com/pinball/forum/topic/need-advice-buying-non-working-pinball and we tried optimising it for printing. Some page elements may have been deliberately hidden.
