I am working on restoring a Gottlieb Big Indian and have almost finished repainting the cabinet, one more stencil to go, that I sanded down to bare wood. Next up is to go through all the relays/switches etc. My question is, can someone take a picture of the board bolted to the inside left wall of the cabinet with the fuse holders. My game is missing the labels for these as well as the fuse going to control bank and drop target reset.
Per the wiring diagram , please correct me if I'm wrong, but the one on the pallet for the control bank with purple and orange wire should be labeled as 1 amp slo-blow?
The one next to the transformer and service plug, should be 5 amp slo-blow?
On the board with the plumb bob, the first one (front to back) with red/black and red wire should be 10amp?
The second with red/white and white should be 10 amp?
The third and most forward fuse on the board with the plumb bob with black red and white wire should be 15 amp fuse?
Lastly, the one fuse for the target bank reset under the play field next to the drop targets should be a 2 amp slo-blow fuse?
Are there any other fuses I may have missed?
Thank you for your help and I will make the necessary placards for my game once I know I'm not missing anything like a service bulletin that changes the fuses.
