I have a sys 6 drive board that I am pulling my hair out on, finally swapped a known working drive board
in the pin in question and all is fine I thought,
Here are the symtoms. I am blowing IC 17 on the switch row column, some times it will take out the PIA
All are in sockets. It will boot fine play for several minutes then blow IC17
even with the proven replacement board I thought it was fixed, then blew a half hour into game play
It has to be in the playfied. but I can not find any issues, I unsoldered suspect diodes for IC 17 string and found no problems on checking, I am stumped where to look next.
