Several months back, I acquired a 1949 Chicago Coin Golden Gloves. It was not working at the time, and I've now got it up and running quite nicely, except for the score reset.
Before anyone says to check the schematic, there doesn't appear to be one... I have literally scoured the planet. In addition to checking all of the usual sources for such things, I've been in touch with woodrail collectors all over the world, and no one has a schematic for this (or a schematic for "Football" or "Tahiti" which appear to be nearly identical with different artwork). In fact, I haven't found a schematic for *ANY* CC machine of this era, so I suspect they don't exist.
Anyway, on to the scoring issue... There are two score steppers in this machine. One manages the 10,000s scores, the other manages the 100,000s. The scoring *works* in so far as the targets score the correct values when hit, but when one starts a new game, it does not reset correctly. The 100,000s resets to 0, the 10,000s steps down to some random value (sometimes to 0, but usually not).
Below is a picture of the 10,000s stepper. I took the picture some months ago before I had the machine working. At the time, I thought the unit may have been something "off the rack", that wouldn't have originally had a coil attached at the top (the rusty spot) since there is a clock spring that "unwinds" the stepper when the lower coil unlocks. I came to that conclusion as there's no cut or noticably missing wiring. It now occurs to me that maybe there *should* be a coil there, and that it must be run in parallel to the coil on the 100,000s unit.
Thoughts on that logic? More importantly, does anyone have a CC machine of this vintage and would you be willing to take a photo of your 10,000s unit and explain to me the wiring of the top coil (if there is indeed on there)?
