I picked this little chip tester up from Borygard when I was at the Chicago Expo. Had the opportunity to actually use it for its intended purpose tonight so I shot a quick video of it. Handy tool.
Quoted from pinball_faz:
that is cool...but a bit pricy for a hobbyist.
Toys!
Calling it a toy is probably fair but at least it is a usable toy.
That's more words than I think I've ever heard Marc say in total, and keep in mind I've seen him in person at least three or four times, lol.
That's pretty awesome...testing ICs if you don't have a documented test pattern by testing continuity or moving to another identical board that is known to work can be a real PITA. Ironically, this thing would probably be worth more to me (a relative novice) than someone like you. You look at it in either parts savings or time savings, and I'm just like...if a 100$ tool can keep the Pinsmith out of my house once... it's PAID FOR!
ebay.com link » Multi Function Ic Led Optocoupler Lm399 Dip Chip Tester Model Number Detector
Is it the same as these $25 IC testers on ebay?
Quoted from Marc:
Our whole hobby...."Toys!"
I could have a really nice car for all I've invested in the hobby....I know some people are worse..but..
This is very cool...and useful.
faz
I could not find it on his website. Looks like a nice little tool to have a round. Is the one on eBay the same or has he done something else to it?
The IC tester I have at shows is basically the same idea as the eBay link. However, countless hours have been spent with the manufacturer to ensure most any pinball related IC you can throw at it were included in its abilities.
Mine will do most all 74xx series TTL ICs, CMOS ICs, literally into the thousands of chips and anything I could possibly think of for pinball related repairs. This includes the common failure WPC switch matrix ICs, LM339, ULN2803 and others.
It's a fantastic tool and the only thing comparable that I'm aware of, are not at all portable, and cost upwards of $600-$1000 if you can find them used.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
Rob;
Very cool little logic IC tester. All these little things coming out lately, I'm going to have to really step up my game to keep up!
-Hans
It's an undeniably cool tool. If it did 5101, 6810, 6264, 62256 memory ICs...I'd have one. Heck...I'll probably still get one...
Chris Hibler - CARGPB #31
http://www.Team-EM.com
Looks like this one lists LM339, ULN2803, etc as part numbers it can test.
Ebay #: 230977852262
"This 's a powerful IC tester with a database of 74 series, 74LS series, 74HC series, 54 series, CD4000 series, HEF4000 series, CD4500 series, etc, in all over 1500 IC types."
Think I'll pick one of these up, for under $28 shipped seems like it would save a ton of time.
Quoted from ChrisHibler:
I've got one that handles MOST of those.
http://www.siegecraft.us/pinball/ramtester.html
I picked up the device that Vid posted the eBay link and it works well to test the all the 74XX and 40XX logic and some of the linear ICs I have in my box. It did not work on a 741 op amp or the UDN7180 UDN6184.
Interestingly, I put LEDs in the socket in any orientation and the device lights them up. It also lights up an LED numeric digit display I have in my box...
I also picked up the transistor/capacitor/diode tester that seller has as well. It works nicely and can tell you value of capaicitors. For example, I replaced a bunch of capacitors in a 1987 machine thinking they all should be trash by now and they all were still working fine (according to the tester). It also identifies NPN, PNP, N and P-channel MOSFETs, SCRs, etc.
These IC testers are very neat, but i don't think they are practical. My issue with these chip testers is you have to desolder the component off the board to test them. That kind of defeats the purpose. I mean you can test new ICs, but that does not seem very helpful.
If you have a locked up board, you desolder everything one by one testing??? That is not a good repair method. Most 74XX and a lot of 40XX ICs can be tested with a DMM on diode test, in circuit, looking for voltage drops or powered with a logic probe using truth tables. This is far less invasive (but not fool proof by any stretch). The 74xx and 40XX ICs are all super cheap, if you have to desolder it to figure out if it is bad, just replace it?
The CMOS RAM tester is much more practical since these ICs are often in a socket and are bad very often.
Andrew
I test new components, so I don't replace bad with bad and then scratch my head for 10 minutes, lol.
Quoted from barakandl:
Andrew
If there's an error and I suspect an IC and desolder it, it's nice to know if that IC was indeed broken, and this tool is usefull for that. I can measure simple Logic gates with a logic probe, but don't know how to measure some others.
Besides if an IC is broken I always place a socket, so if after replacement there's still/again an error, I can easily taak the IC out and now I can test it as well very quickly, to see if the new one blew as well (if so, than a new search starts ).
This tester is a great tool for all pinballers, a real sweety
Following a list, what components can be tested.
This is a powerful IC tester with a database of 74 series, 74LS series, 74HC series, 54 series, CD4000 series, HEF4000 series, CD4500 series, etc, in all over 1500 IC types.. The commonly seen ICs are included in its test range, such as below:
74LS00 74LS01 74LS02 74LS03 74LS04 74LS05 74LS06 74LS07 74LS08 74LS09 74LS10 74LS11 74LS12 74LS13 74LS14 74LS15 74LS19 74LS20 74LS21 74LS22 74LS26 74LS27 74LS30 74LS32 74LS36 74LS37 74LS38 74LS40 74LS42 74LS45 74LS47 74LS48 74LS51 74LS54 74LS55 74LS64 74LS73 74LS74 74LS75 74LS76 74LS78 74LS83 74LS85 74LS86 74LS90 74LS92 74LS93 74LS107 74LS109 74LS112 74LS113 74LS114 74LS125 74LS126 74LS132 74LS133 74LS136 74LS137 74LS138 74LS139 74LS145 74LS147 74LS148 74LS151 74LS152 74LS153 74LS154 74LS155 74LS156 74LS157 74LS158 74LS160 74LS161 74LS162 74LS163 74LS164 74LS165 74LS166 74LS168 74LS169 74LS170 74LS173 74LS174 74LS175 74LS177 74LS180 74LS182 74LS190 74LS191 74LS192 74LS193 74LS194 74LS195 74LS196 74LS197 74LS240 74LS241 74LS242 74LS243 74LS244 74LS245 74LS247 74LS248 74LS251 74LS253 74LS257 74LS258 74LS260 74LS266 74LS273 74LS279 74LS280 74LS283 74LS293 74LS298 74LS365 74LS366 74LS367 74LS368 74LS373 74LS374 74LS375 74LS377 74LS378 74LS379 74LS390 74LS393 74LS465 74LS540 74LS541 74LS573 74LS574 74LS595 74LS640 74LS642 74LS645 74LS670
74HC00 74HC01 74HC02 74HC03 74HC04 74HC05 74HC06 74HC07 74HC08 74HC09 74HC10 74HC11 74HC12 74HC13 74HC14 74HC15 74HC19 74HC20 74HC21 74HC22 74HC26 74HC27 74HC30 74HC32 74HC36 74HC37 74HC38 74HC40 74HC42 74HC45 74HC47 74HC48 74HC51 74HC54 74HC55 74HC64 74HC73 74HC74 74HC75 74HC76 74HC78 74HC83 74HC85 74HC86 74HC90 74HC92 74HC93 74HC107 74HC109 74HC112 74HC113 74HC114 74HC125 74HC126 74HC132 74HC133 74HC136 74HC137 74HC138 74HC139 74HC145 74HC147 74HC148 74HC151 74HC152 74HC153 74HC154 74HC155 74HC156 74HC157 74HC158 74HC160 74HC161 74HC162 74HC163 74HC164 74HC165 74HC166 74HC168 74HC169 74HC170 74HC173 74HC174 74HC175 74HC177 74HC180 74HC182 74HC190 74HC191 74HC192 74HC193 74HC194 74HC195 74HC196 74HC197 74HC240 74HC241 74HC242 74HC243 74HC244 74HC245 74HC247 74HC248 74HC251 74HC253 74HC257 74HC258 74HC260 74HC266 74HC273 74HC279 74HC280 74HC283 74HC293 74HC298 74HC365 74HC366 74HC367 74HC368 74HC373 74HC374 74HC375 74HC377 74HC378 74HC379 74HC390 74HC393 74HC465 74HC540 74HC541 74HC573 74HC574 74HC595 74HC640 74HC642 74HC645 74HC670
CD4000 CD4001 CD4002 CD4006 CD4007 CD4008 CD4009 CD4010 CD4011 CD4012 CD4013 CD4014 CD4015 CD4016 CD4017 CD4018 CD4019 CD4020 CD4021 CD4022 CD4023 CD4024 CD4025 CD4026 CD4027 CD4028 CD4029 CD4030 CD4033 CD4035 CD4040 CD4042 CD4043 CD4044 CD4048 CD4049 CD4050 CD4051 CD4052 CD4053 CD4060 CD4066 CD4067 CD4068 CD4069 CD4070 CD4071 CD4072 CD4073 CD4075 CD4076 CD4077 CD4078 CD4081 CD4082 CD4085 CD4093 CD4094 CD4099 CD4501 CD4502 CD4503 CD4504 CD4508 CD4510 CD4511 CD4512 CD4513 CD4514 CD4515 CD4516 CD4518 CD4519 CD4520 CD4522 CD4526 CD4529 CD4532 CD4539 CD4543 CD4553 CD4555 CD4556 CD4584 CD4585 CD40106 CD40107 CD40110 CD40147 CD40161 CD40162 CD40174 CD40175 CD40182 CD40192 CD40193 CD40194
Also, below components can also be tested and detected by the tester:
LM324 LM339 LM393 LM358 LM386
TDA2822 TDA2822M
NE555 7555 NE556 7556
ULN2003 ULN2004 ULN2803 ULN2804
PC817
NEC2501
TLP521-1 PC827 TLP521-2 PC837 TLP521-3 PC847 TLP521-4 4N25 4N35
LED, LED Matrix Pads
Quoted from SealClubber:
So where does one buy this doodad? I don't see it on Borygard's site.
Email him off the site, PM him here. Do the bruscheta rain dance.
It's on eBay for under $30 shipped.. read through the posts again on this thread and you'll find several links or auction numbers. I bought one and just received it a few days ago. It makes testing logic chips that are socketed on old arcade boards a breeze. I was able to test 60 chips on 3 different boards (20 ICs per board) in under 30 min.. it took more time to get them back in their sockets! I guess they're hiding some of the circuitry under the ZIF socket or labels cause there's not much visible circuitry on it. I'd imagine it's identifying chips based on the voltages on each of their pins when powered up (creating a unique chip signature)..but that's just a guess. It does a nice job and is very quick identifying the chips. A marvel of a tool
Quoted from vid1900:
Do you remember the "Parametric Analyzer" from the late '70's/early '80's sold mainly into the amusement and gaming repair industry? It was connected it to the inputs of a dual trace scope.
It was pretty handy back then for testing a lot of IC's in circuit when you had a catastrophic failure not allowing the board to power up.
Thanks. Ace, Borygard said that the one on ebay wasn't his and doesn't test as many chips.
It appears these testers are manufactured in China and the units being sold on eBay can test the additional chips that were mentioned by Borygard as pinball specific. They're also sold on international B2B portals where cheap electronic components and other goods can be had for wholesale costs like Aliexpress / Alibaba -- http://www.aliexpress.com/item/Multi-functional-IC-74-CD4000-CD4500-series-IC-NO-checker-LED-Tester-Detector/937334129.html ($20.99ea for 10 pieces or more).
Many people don't want to deal with importing stuff from overseas, but US companies often have to source products to either resell or components/materials for end goods from international sellers.. otherwise costs of end products would be far too high for most people to want to purchase it. There are sometimes shady international sellers, language barriers, product received is not the represented product, etc.. but there are also many good sellers too. Of course.. the more people that buy something for wholesale from those sellers.. the more that pop up on eBay and the more competitive it would get for the same product to be sold on eBay. That's the downside to wholesale sourcing and the internet.. but that's another story.
Not saying there aren't additional chips the unit Borygard is able to test, but so far none of the additional chips that were mentioned are different than what is in the description on the eBay links. It's still good to support people in the hobby when you can, nothing wrong with that. You also wouldn't have to wait 3-4 weeks like you will if you order from an overseas seller.
I for one am very glad this IC tester was mentioned by the OP because it just saved me hours of time diagnosing a few arcade boards that were purely based on 74xx logic. Found 4 bad chips and replaced. The boards still had issues, but turned out the remaining issues were bad 7805 voltage regulators.. but since I knew the logic chips were good I could diagnose elsewhere.
Quoted from MrBally:
That brings back memories.
I wonder if anyone still has/uses one?
If anyone wants one of mine, just email me. I can't come close to the ebay price because they cost me much more than that in bulk. I also can't comment on the ebay one as I haven't specifically used it, but it wouldn't surprise me if it was running the exact same code at this point. It sucks, as I said I've put a great deal of time into mine. Such is the way of these things though, and why the world is full of cheap knockoffs of everything.
I also have the RAM testers available in kits or ready to use.
Rob Anthony
Pinball Classics
Quoted from Borygard:
Rob Anthony
Not really a case of a cheap knockoff here though, I get what you're saying for other things but this hardware already existed right? And it was originally created and manufactured by a developer in China as a logic IC tester.. so any new capabilities suggested by customers would very likely make it into the new units. Sometimes there's deals worked out to keep things exclusive, but usually that costs big $$ since it would then affect sales of the version that lacks those capabilities.
I'm actually curious in knowing more technical details on how it identifies the chips if you know anything about it? I'm assuming voltage characteristics when the chips are powered on? Hoped you might know since you worked with the developer to get it working with some new chips. Fascinating stuff, for now I'll just marvel at it
