So I have been brain storming the NBAFB and have had several issues with the flashers. Replaced the corresponding diodes (WPC95). The 104 LED is still out but there is power (21.4v) at the test point. Maybe the led blew? Other issue is the low power sol don't work now, (slings, pops, outhole, through) They previouly did. Test point at the sol 50v is 74.1v. The capacitor tests at 74.1 as well. (100uf x100v) . This is much higher than its suppose to be. The Flippers work fine. Fuses are good and test. Diodes are at 34.1v. Any ideas were to start? Usually low voltage is the issue and I would replace the cap and diodes, but high voltage?
