Picked up a NBAFB a couple weeks ago. Everything was fine. In the coin box were the newest roms. Not sure why never installed by previous owner but popped them in last week. Everything ok for a few days then factory settings restored. ???? Checked voltage at U8 and low. Pulled batteries and a little green on the contacts like maybe a little past leakage but board looks clean. Sanded a little and now 4.5v at U8. Fired back up and went into settings to set date/time and it locked up and reset. Then dead. Disconnected everything from MPU and same. 201 and 202 solid. 203 off but would give a little blip here and there but rarely. Took board out to inspect again and put back and it booted up. Connected everything and ran for a couple minutes then froze and reset then died. After more attempts MPU booted with ribbons attached but no 501 on AV board. Touched ASIC at U9 and 501 lit on AV but MPU went back to 201 and 202 solid and 203 off. I ordered a tool to remove ASIC and did that yesterday. Re-seated and it boots every time now. Game fires up and plays but now the ball eject fires a lot randomly. Tried to find consistency in when. Seemed to happen most when defender motor moving or when a ball is in the left eject saucer and the timed backbox flipper shots are going. But happens other times as well. Sometimes it will fire all the balls out but generally I can feel the eject fire but not strong enough to get a ball out. They stay in the trough it just keeps going. Along with that I found that when "in the paint" was started the defender magnet would steal the ball or it would shoot. I couldn't pass. Some games last night were clean. "In the paint" was normal and no eject pops. But when whatever happens happens it causes the "in the paint" to not work and the eject fires. Swapped out trough optos with my WCS94 and same result. Not sure where to look now. Is this an MPU problem since it started after changes there? In test the defender optos weren't all registering. Cleaned and are good now. I noticed in switch matrix the defender optos are showing opened and close when the opto is triggered but they are listed as normally closed in the matrix like the other optos. Is that normal or is that a sign of something being off? It was also late last night so maybe confused but only defender locked opto had the X and the others were dots. Made me confused. Thanks for any help.
