Hey everyone!
I have a 2 fold issue with my nba fastbreak I believe. I’ll do my best to explain:
If any bulbs are connected in row 7, and you test any bulb in column 1, the bulb you’re testing will light along with the bulb in that column but row 7 as well as the bulb that’s in the same row as what you’re testing but column 7. This will not happen if you test any of these other bulbs. Only when you test the lamps in column 1.
The behavior is the same if you test the next column. The same column row 7 will light and the same row column 7 will light.
Now. Issue two. If you test any bulb in column 6, the adjacent bulb in column 7 will light. If you test the bulbs in column 7, everything is fine.
If I remove all bulbs from row 7, all the lamps test fine until I get to column 6. This makes me think I have two issues.
I have attached a pic of the lamp matrix for reference. Thanks for the help!
