Hi All -
I'm not the most electrical-inclined, and I'm experiencing quite a frustrating issue with my NBA Fastbreak. With social distancing in full effect, I feel this would be a great time for me to dive in and try to learn!
I picked up this NBA Fastbreak not working, so it's not acting up because of an issue or mistake that I have made. Upon start up, I noticed that F103 kept on blowing. I started to disconnect some of the coils feeding that fuse, and it seems most of my high power coils are locking on. Upon disconnecting one coil, the next coil starts to lock on. Now, the fuse will not blow, but coil 6, which is the upper loop gate stays engaged upon starting the machine.
If one coil was locked on, I would suspect I would check out the specific 'Q' transistor on the driver board, but this issue seems more widespread as it's affecting every coil being driven from connector J116.
Any help, guidance, or attention of any kind if appreciated! Apologies if above was hard to read - I've been self-handicapped having friends much more gifted than me, but what a time it is to be self reliant!
