(Topic ID: 153483)
NBA Fastbreak Fanatics Club!
By Rascal_H
  • 475 posts
  • 106 Pinsiders participating
  • Latest reply 2 days ago by joelbob
  • Topic is favorited by 43 Pinsiders
There have been 109 images uploaded to this topic. (View topic image gallery).
There are 475 posts in this topic. You are on page 9 of 10.
#401 59 days ago
https://littleshopofgames.com/shop/playfield-plastics/playfield-plastics-complete-sets/nba-fastbreak-back-box-plastic-set-nbafb/
I’m going to get new backbox plastics. I also need the plastic fasteners that attach these guides to the backbox. Anyone know what they are called and where to get them?
#402 59 days ago
Quoted from chuckwurt:
Something like those I assume?
https://www.pinballlife.com/pcb-standoffspacer-12.html
#403 59 days ago
plenty of details in the manual it seems
#405 59 days ago
I bought this kit, has both the plastics and standoffs needed:
https://www.marcospecialties.com/pinball-parts/31-2814-XX
#406 57 days ago
I just installed that plastic set from Marco's, looks like it might have been their last one too. Sorry about that, but my backbox needed some rehab! Got some new backdrop art, plastic set, and a whole lot of Novus and elbow grease on the translite to make it look new!
Wanted to retrobrite the lamp sockets, but hydrogen peroxide is in short supply, and I wasnt sure how smart it was to do in the first place.
This is my first table, just picked it up a few weeks ago after a 16 hour non stop round trip! Love how fast it is, and I am a happy new member of the club.
If this is a faux pas I apologize, but I have a tech support question? I am hearing a humming coming from the right side of the table, seems to correlate to the operation and general vicinity of the right loop diverter; is that indicative of a coil in need of replacement? Just kinda hums for extended periods of time, and it seems shots bust right through and end up in the paint regardless of what is lit.
ps if anyone wants the pictured plastics I uninstalled, seems they might clean up ok and be serviceable, I will happily send them to anyone that sends me a self addressed envelope at no charge. Pretty sure its a complete set, but a little grimy, and one piece has had some tape repair work done to it. It played just fine though.
Backboxdirt2 (resized).jpgBackboxclean2 (resized).jpgBackboxdirt (resized).jpgBackboxclean (resized).jpg
#407 57 days ago
I got a set of backbox plastics from here.
https://www.pinballspareparts.com.au/a-31-2814.html
#408 57 days ago
I took the shoot button off because the light was burned out and now after I press it a few times in a game it pushes the piece down a little and it does not hit the little switch button. Is there a way to secure the light insert piece that holds it firmly in place?
#409 57 days ago
Quoted from Acronymicon:
ps if anyone wants the pictured plastics I uninstalled, seems they might clean up ok and be serviceable, I will happily send them to anyone that sends me a self addressed envelope at no charge. Pretty sure its a complete set, but a little grimy, and one piece has had some tape repair work done to it. It played just fine though.[quoted image][quoted image][quoted image][quoted image]
What did you use to clean up the white tub? If Novus, Novus 1, 2 or 3? This tub seems to be unobtainable. Also, does anyone know if the backbox switch is available for purchase? Thanks!
#410 56 days ago
Quoted from KozMckPinball:
After stripping it completely I used a magic eraser and an only slightly diluted mix of simple green. I let it soak a bit and went over it 3 times.
Thankfully the original background art didnt leave much of a mess behind with adhesive.
I was worried I was going to end up breaking it and have to buy a light tub and punch holes in it myself, but it was a pretty easy process altogether.
I couldnt find the backbox rollover switch for purchase; it has a diode across some of its legs, so I am guessing its not interchangeable? Luckily mine still works fine, if not I was going to use a more accessible rollover and solder the diode on there and hope for the best.
Novus I used to clean up the translite as mine was dinged up, and it worked really well. Looks almost new.
Just got my first trophy.. well as it drained it said "trophy complete!" so I didnt have much time to enjoy it but I still felt it.
Loving this table!
#411 56 days ago
What did you use for new adhesive for the art panel to the tub?
#412 56 days ago
The replacement is a big sticker basically. Its think too; no need to worry about bubbles.
#413 55 days ago
Thanks. I have the replacement art as well. Starting my NBAFB restore soon.
#414 55 days ago
post pics!
I got a decal set for mine, but I gotta wait for it to warm up before I bondo/paint and apply them.
#415 54 days ago
Quoted from Don44:
Anybody?
#416 54 days ago
Go back and make sure you put it back together correctly.
#417 54 days ago
The switch part with the light attached is easily pulled from the shoot button part. If I press down on that with my finger the button part clicks the switch otherwise it does not reach quite far enough to click it every time. I’m pretty sure I have it hooked up right
#418 54 days ago
Looks fine to me. While holding it like that push the shoot button and make sure it’s moving freely and not binding. Something happened when you took it apart and put it back together. I assume there was no issues with the button before?
#419 54 days ago
There was not any issues previously. The shoot button moves freely up and down as well. Is something supposed to hold the switch assembly in place?
#420 54 days ago
Quoted from Don44:
Yeah the plastic housing surrounding it. Looks like yours is there. The switch should be snug.
440C4002-A077-4302-B11C-9F6A62739FF5 (resized).jpeg9EAEC8FC-C1F9-4920-A675-4BBD56C0D724 (resized).jpeg
#421 54 days ago
On the one I had you had to add a bit of force to reseat the switch assembly back into the shoot button. It would feel like you bottomed out the switch into the button but if you pressed the button you could see the white prongs not fully pressing the black nub of the microswitch down.
#422 54 days ago
Do you have the inner part of the the switch properly seated into the tabs on the switch and check the female sta-kons make sure they still got a good bite on the terminals of the switch.
#423 53 days ago
Thanks guys, the picture really helped. I didn’t have the light bulb piece snapped down into the shoot button. I really had to push hard with a screwdriver but it does snap into place.
#424 36 days ago
Has anyone had an issue with resetting mid game? Just started happening. No evidence of battery leakage. Thanks for any thoughts
#425 36 days ago
My understanding is you have a power issue. Dropping the 5 volts I believe. That’s precisely where my knowledge ends. Haha
#426 36 days ago
I have been working on a project machine where i had to replace the translite and the backbox glass. I am not sure I am able to keep the translite as flush as it could against the glass when I put the trim on and it seems the translite catch the ball once in a while...
Am I missing a post inside the assembly to keep the translite flush against the glass to avoid getting the ball stuck? The repro ball seems the same size as teh beat up original so I don't think that's it... why is it so cramped in there?!?
#427 36 days ago
Just joined the club! This is a great game!
#428 35 days ago
Quoted from hisokajp:
do you have the standoffs that go from the ball guides the the translite installed ?
#429 35 days ago
Quoted from marioparty34:
Just joined the club! This is a great game![quoted image]
nice game can you tell me what colour they went with on dennis rodmans hair? i going to put one in mine i think
#430 35 days ago
The standoffs seem too short. They should be longer like the ones you have over by the guides by the flipper. They should be the same ones all the way around.
#431 34 days ago
Quoted from Joka:
Joka- Here you go. Rodman's hair is a nice canary yellow. The game really benefits from a colordmd. Highly recommended.
#432 34 days ago
Joka- Here you go. Rodman's hair is a nice canary yellow. The game really benefits from a colordmd. Highly recommended.[quoted image]
love it! you sold me. you have lcd or led? im thinking led
#433 34 days ago
Quoted from Joka:
LED all the way!
#434 34 days ago
LED all the way!
Great to hear you have LED yours looks mint
#435 34 days ago
Quoted from Joka:
I tried to follow the manual and look at picture but i could not see any of those? The manual legend call for some 1/2" standoff but the drawing doesn't show where it goes...
I used the size mentioned in the manual, 3/4" tall standoff
This is what mine looks like, the 3 plastics in the middlehave holes in the center, should i put 3x 1/2 standoff there?
#436 34 days ago
Not sure. Yours might be right. Not sure what your issue is.
#437 34 days ago
I'm completely missing the light tub in my project
Anyone know where I might find one?
#438 34 days ago
LED all the way!
Now I'm sold on the LED. Thanks for that.
#439 34 days ago
Quoted from dc2010:
they are on ebay for sale
https://www.ebay.com.au/itm/NBA-Fastbreak-Backbox-Globe-Tray-Inner-Mr-Pinball/151367168143?hash=item233e2fb08f:g:CAIAAOSwEK9T1eIK
#440 34 days ago
yes your missing the standoffs that go out to the translite
put the smaller standoffs through those holes in the middle plastics, ill send a pic if you need more help
#441 33 days ago
Quoted from AFM95:
I just want to say that I miss being in this club! Such a fun game.
I'm back in the club! Nothing like dropping 187 with the Washington Bullets, only to lose trophy multi-ball by a point.
Are you guys going LCD or LED for the color DMD?
#442 33 days ago
Quoted from Joka:
that did it, 3x 1/2" standoff and there is no problem with hang up now.
#443 33 days ago
Quoted from AFM95:
Are you guys going LCD or LED for the color DMD?[quoted image]
Nice man it is decided led is the go, like your LED light layout
#444 33 days ago
Perfect
#445 33 days ago
Quoted from AFM95:
I went LED in mine and it looks great.
#446 33 days ago
Just got my first ring and was so close to a second. Does anything special happen when you get all the rings for every team?
#447 33 days ago
Quoted from AFM95:
I
LCD Here.
LED on WPC95 does not look very nice in my opinion.
#448 33 days ago
Quoted from Joka:
Quoted from joelbob:
Quoted from moTiv8:
LCD Here.
I appreciate everyone's feedback. Thank you.
#449 32 days ago
More then likely your initials for that team. Nothing happens collecting rings for every team. You just make it harder for some else to get the high score for that time because now they have to get the same number of rings or more plus beat high score.
#450 28 days ago
Quoted from moTiv8:
LCD Here.
Do you mind posting a pic of the LCD?
$ 37.50
$ 89.99
3,800 (OBO)
Orange Park, FL
$ 50.00
