(Topic ID: 153483)
NBA Fastbreak Fanatics Club!
By Rascal_H
8 years ago
  • 1,320 posts
  • 198 Pinsiders participating
  • Latest reply 20 days ago by jcar302
  • Topic is favorited by 93 Pinsiders
There are 1,320 posts in this topic. You are on page 27 of 27.
#1301 60 days ago
Quoted from Nintegageo:
Any advice on lowering the magnet near the hoop? It's raised enough that I'd like to make it more level with the playfield. Thanks
I never paid much attention to the magnet, if there is no adjustment, place a washer on the base of the support to level it.
#1302 57 days ago
Does anyone know if a replacement can be purchased for the red pop bumper "ring and rod" piece? This would be the one that has a portion of it trimmed off to fit in the space next to the metal guide piece. I trimmed my own plastic skirts when I replaced them, but now need the metal ring and rod as mine just broke.
Or do you just have to trim it yourself from a regular ring and rod part? Any advice on how to do that? Dremel?
#1303 57 days ago
Quoted from Leonardogit:
Thanks, the issue was due to a playfield protector. Decided to just cut around the magnet and voilà. Solution!
#1304 57 days ago
Quoted from AlexRogan84:
It's a standard pop bumper part. The only "modified" piece is is the skirt/wafer and that is available but since you made your own you don't need it I guess.
https://www.marcospecialties.com/pinball-parts/03-9809
#1305 57 days ago
Quoted from SimplePin:
My ring and rod part for just that red pop bumper is also modified. Isn't yours too?
#1306 57 days ago
Here's a picture of mine from an earlier post. Would be great if that little slice removed isn't actually stock or necessary.
https://pinside.com/pinball/forum/topic/nba-fastbreak-fanatics-club/page/23#post-7920459
#1307 57 days ago
Mine is not. I rebuilt all three pops last fall. There is some adjustment that can be made to the ball guide if you loosen it and then reposition before tightening. I adjusted mine when I rebuilt the pops to "steer" the ball away from STDM's
#1308 56 days ago
Thanks for that! Makes the repair pretty straight forward now. Just gotta get some parts ordered...
#1309 48 days ago
put a new rubber grommet on the coil that passes to player 1, when this rubber is worn out the plunger becomes magnetized and loses power
Happy to announce that I changed out the grommet and surprisingly everything works really well. 20 in a row passing left from shooter 2 to Shooter 1. I will update this post if things go south.
Mike V.
#1310 47 days ago
hey guys, just picked up a project . shooter 1 and 2 will pass but not shoot, anybody tell me which fuses and transistors control those two ? i don't have a book to look at.
#1312 47 days ago
Quoted from ccbiggsoo7:
the transistor that controls shooter 1 is Q84, the transistor that controls shooter 2 is Q86, all shooters are part of the flipper circuit so check fuses F115, F116, F117 and F118 located at the bottom right on the driver board above J119
Screenshot_20240605-111032 (1) (resized).pngScreenshot_20240605-111032 (1) (resized).pngScreenshot_20240605-110912 (1) (resized).pngScreenshot_20240605-110912 (1) (resized).png
3 weeks later
#1313 26 days ago
Anyone get a lot of airballs off the "3" target? This is the round purple one to the left of the centre ramp. I replaced mine with a new one (the one in the game was blue when I got it). Target works well, foam backing is intact, mounting bracket underneath looks to be correct. And I don't aim for it on purpose, but if you miss your ramp shot and hit it dead on, holy cow does the ball ever fly. I've had it hit the glass and also jump right over the flippers into the trough. My flippers were rebuilt recently and everything is crisp and snappy. Maybe that's the problem, lol.
I have put clear plastics overtop certain targets on other games (centre drop targets on LW3 and drop target on Spook house in Cyclone). Wasn't sure if that was feasible on NBAFB?
#1314 26 days ago
Quoted from AlexRogan84:Anyone get a lot of airballs off the "3" target? This is the round purple one to the left of the centre ramp. I replaced mine with a new one (the one in the game was blue when I got it). Target works well, foam backing is intact, mounting bracket underneath looks to be correct. And I don't aim for it on purpose, but if you miss your ramp shot and hit it dead on, holy cow does the ball ever fly. I've had it hit the glass and also jump right over the flippers into the trough. My flippers were rebuilt recently and everything is crisp and snappy. Maybe that's the problem, lol.
which coils are you using on the flippers? the flipper on the left uses the FL-11753 coil (low power) and the one on the right uses FL-11630 (medium power)
#1315 26 days ago
Thank you! I hadn't thought to double check that before... or maybe I did. Can I get some confirmation on these coils please? The manual shows FL-11630 (red) on both left and right flippers and the FL-11753 (yellow) coil only in the backbox.
I could try and go lower on the main flippers though anyway and see how it plays. Anyone else have different coil strengths in their flippers?
#1316 26 days ago
you're right, FL-11630 goes on both flippers, mine has been mounted with FL-11753 since when I bought the machine, maybe the previous owner mounted it that way to protect the right ramp from breaking
#1317 22 days ago
Does anyone know where I can get the roller for the defender or is there a3d print file available
#1318 20 days ago
Quoted from roboclan:
Hi. I dont know. But that whell look pretty much alike like the sliding door wheels at Homedepot or Loves. Good luck
#1319 20 days ago
Quoted from Santis:Hi. I dont know. But that whell look pretty much alike like the sliding door wheels at Homedepot or Loves. Good luck
Vastly different size but I agree. You should be able to find and equivalent part out in the hardware world somewhere.
#1320 20 days ago
I bet you could measure it and just use a real roller bearing.
PinSound
Nezzy's Pinball Prints
$ 199.00
$ 89.99
$ 12.50
Trade
Machine - For Trade
Mars, PA
$ 24.50
Playfield - Plastics
$ 89.99
$ 45.95
KAHR.US Circuits
4,400 (OBO)
Algonquin, IL
$ 29.00
Filament Printing
5,495
Linn Creek, MO
$ 9.95
4,175 (OBO)
$ 18.50
Great pinball charity
Pinball Edu
