Hello all. Recently picked up a Bally Nashville. It’s in great shape cosmetically, but of course has some playing issues. After tinkering with it for a while, I can now “play” a game. That is, I can hit the coin switch, and the cards and features activate as they should, a ball kicks up, and the numbers, for the most part, light up as they should. There are a few that light on cards 1-3, but not 4-6 and vice versa). Hitting the C button will search for winners, and for the most part finds them (it misses a win every once in a while, and it always thinks card 2 is a winner), but the primary issue I’m having right now is, it doesn’t successfully award wins on the replay register. I can see that the wiper on the corresponding replay counter has moved off of zero, and hitting the R button causes the replay counter to step back to 0, but no credits are awarded. If I manually add credits, I can use them to play, and the replay register successfully resets to 0 when the machine is started, it just doesn’t add them, either through winning or hitting the coin switch. I’m happy for any troubleshooting advice for any of those issues, but I guess my specific questions are:
Should the, (I’m not sure what they’re called) wires that run in the grooves on the search disks all be in the same orientation? The manual only shows the layout on the control unit, with the 4 wire side running in grooves 1, 3, 5, and 7, and the 3 wire side running in grooves 2, 4, and 6. Should the other search disks be that way as well? Mine weren’t, and I’ve moved them into this arrangement, and it cleared up some of the trouble I had with random numbers lighting up, so I assume that’s correct, but just want to verify. Diagram from the manual below.
Should the search disks part at 0? The one for cards 1 & 2 does, but the 3 & 4 and 5 & 6 don’t seem to. Pics below.
Thanks for any help or advice you can provide. I think this is a very cool game, and would really like to get it running properly.
20230208_212350 (resized).jpg20230208_212357 (resized).jpg20230208_212412 (resized).jpgScreenshot 2023-02-09 101411 (resized).jpg
