Quoted from MustangPaul:Nope I don't. Without it does your sling plastic sit level? For some reason that plastic post looks shorter then mine. Do you have a star post on each sling down by the apron?
Yes, there is a star post on each sling closest to the apron.
Quoted from dementedwarlok:Actually have a pic of my sling and cropped a pic of ramp entrance rubber.
For your sling I take it you don't this white spacer either?
I can't tell from your ramp pic if the left and right entrances use black rubber or if it's hard plastic. Are they rubbers? Actually I can't tell anything from your pic because it's too dark and there are too many reflections. Sorry. Do you have the same photo but in the light with the machine off?
[EDIT]
Okay, I looked in the manual. Damn Stern puts together a fantastic manual! The left post for the right ramp is supposed to have a #6-32 in the top. No washer. Both posts get black rubber posts.
For the sling, that spacer isn't supposed to be there. I'm guessing at one point it was accidentally moved from the ball return guides. I'll know for sure when I put those back together.
While I'm in posting, does anyone have a spare lightning plastic for sale? It's the long weird shaped one that is along the left side of the right ramp. Mine is busted into 3 pieces. It's no. -17 in the manual.
