I replaced the coil and a new diode and it continues to blow the fuse. I checked the wires to make sure the wires were not shorted to ground. I was going to send the boards out for service to find out if the transistor was the issue.
Quoted from hawkeyexx:I replaced the coil and a new diode and it continues to blow the fuse. I checked the wires to make sure the wires were not shorted to ground. I was going to send the boards out for service to find out if the transistor was the issue.
Ah yes I remember you saying you replaced them. Likely the transistor is shorted at this point, it's not super difficult to troubleshoot if you have a DMM, however if you'd rather send the board out for repair I'd understand.
I do have a DMM but I do not know the procedure of testing a transistors with it installed in the board.
Nurbtadtic, remove the coil and inspect the diode to ensure it indeed making contact across both coil lugs?
Quoted from trueno92:Nurbtadtic, remove the coil and inspect the diode to ensure it indeed making contact across both coil lugs?
I didn't have my camera at the time but I assure you it was. I'm starting to think the transistors I have may be counterfeit, so I'll wait til my replacements from Marco come in and update once I swap those in.
Make sure to test the trannys before you install them. You may need to ground them out first which just means bridging the leads with a screw driver before install
This why I'm not an expert on diagnose a pinball machines. I wish I had more time to be around people that understand what to check for and why...
I'm still shopping for a grand prix if any of you wonderful people are interested in leaving the club so I can join it. Lol
Update, Put the transistor I got from marco in.. and presto! it works now without locking the coil. My machine has a nasty lean rn from working on it, but I'll level it out tomorrow probably and try some full test games, I shot the left ramp and the coil fired perfectly, looks like we may be back in business. I'll update again but I figured I'd share it here.
Still in the market.
Quoted from trueno92:Should be many out there! And man it’s such a great game when it’s working as it should!!
Quoted from jrcmlc:Still in the market.
Likely may take some patience, this is a game where they come up, but not all the time. I'm also not sure how many Grand Prix were specifically made.
10-4. I'm waiting. Patiently. Sort of lol.
Quoted from MrNurbtastic:Likely may take some patience, this is a game where they come up, but not all the time. I'm also not sure how many Grand Prix were specifically made.
Quoted from MrNurbtastic:Update, Put the transistor I got from marco in.. and presto! it works now without locking the coil. My machine has a nasty lean rn from working on it, but I'll level it out tomorrow probably and try some full test games, I shot the left ramp and the coil fired perfectly, looks like we may be back in business. I'll update again but I figured I'd share it here.
Congratulations on getting it repaired
Quoted from hawkeyexx:Congratulations on getting it repaired
Thanks! Luckily we have a lot of helpful people here on pinside to help my amateur self work through issues. Good luck getting yours back on the right track! Hopefully you can get yours on the right track and that it's nothing too difficult, I'm usually in this thread looking anyway.
Awesome!
So I put in a new transistor for my truck issue and no dice. Same behaviour. Pretty sure that transistor tested back but I guess not..
Back to the drawing board for me.
all fixed up, see the progress in the thread here:
https://pinside.com/pinball/forum/topic/whitestar-driver-board-irl540n-driving-a-motor#post-7586795
So I'm finally back on Dale Jr on the topside tear down and making some changes. I decided to replace the pop bumper skrits to transparent red and go with red pop bumper caps on all three. For lightning inside the pop bumper cap I'm using this from comet pinball. https://www.cometpinball.com/products/pop-bumper-discs
I will say dealing with the wiring for pop bumper sucks.....
Let know your thoughts on the skirt colors....
20230528_075823 (resized).jpg20230528_075907 (resized).jpg20230528_080224 (resized).jpgThose skirts look pretty good.yes the wiring sucks as u get to see how much junk is crammed on the bottom, watch for the diode strip where iirc some of the pop switches have their diodes relocated there.
Quoted from hawkeyexx:So I'm finally back on Dale Jr on the topside tear down and making some changes. I decided to replace the pop bumper skrits to transparent red and go with red pop bumper caps on all three. For lightning inside the pop bumper cap I'm using this from comet pinball. https://www.cometpinball.com/products/pop-bumper-discs
I went with a different version of those LEDs on my pop bumpers and it's 1000% improvement. So much brighter that the standard LED bulbs.
I really wanted to make that truck a smaller truck opening in front of a race track grandstand or something. The layout can totally bag a nicer theme. Has so much going for it…
Quoted from trueno92:I really wanted to make that truck a smaller truck opening in front of a race track grandstand or something. The layout can totally bag a nicer theme. Has so much going for it…
Agreed. The truck sucks. There is so much potential in this game for great logos and images but I'm sure it would have cost Stern a fortune for all the rights to use them, so we ended up with generic graphics. Just look at the stickers on the spinners. Lame!
The lighting on the truck is terrible, but the whole truck needs to be updated with a scale model.
Quoted from Fifty:Agreed. The truck sucks. There is so much potential in this game for great logos and images but I'm sure it would have cost Stern a fortune for all the rights to use them, so we ended up with generic graphics. Just look at the stickers on the spinners. Lame!
Yup, this and the habittrail diverter being a flag tower would be awesome.. just no time.
And a pin sound card to modify the sounds.
It's completely assembled. Now I need to figure out why the garage up and down coil blows the fuse.
Additional items will be added....
Pinsound Card
Color DMD
Do something with the car hauler
Pinblades
HD Glass
Dale Jr is going to sign the back glass
Any thoughts on better grade of a steel pinballs?
Any items people would suggest.......?
Nice list of stuff to do. You covered all the bases, maybe get the hurst shooter rod and some checkered flag emblems as speaker decals.
One thing that makes a huge difference is adding an LED OCD board if you are running leds for the inserts. If i had a choice between colordmd and ledocd, id go led ocd as there are some great insert animations and the fade contriol makes a huge difference.
If dale is gonna sign the translite, id take the apron as well and have him sign it in nice broad silver metallic marker.
Just adding this back again, not trying to spam, but for the love of baby jesus, someone sell me a Grand Prix. LOL Happy Memorial Day everyone, thanks to anyone who served, serves, or supports.
Quoted from jrcmlc:Just adding this back again, not trying to spam, but for the love of baby jesus, someone sell me a Grand Prix. LOL Happy Memorial Day everyone, thanks to anyone who served, serves, or supports.
Grandprix is goong to be a bit more rare as all grandprix were export for eu only, while domestic was all nascar.
Ya... I know. There are quite a few here in the US, I just need to find one of you ready to change games. LOL. I caught the last one right as it sold and another that's on route is beat to shit but the guy won't sell it, just keeps running it beat to shit lol
Quoted from trueno92:Nice list of stuff to do. You covered all the bases, maybe get the hurst shooter rod and some checkered flag emblems as speaker decals.
I have the Hurst Shooter rod installed. I upgraded to LEDS and Titan Rings. Purchased new apron cards.
The Tach mod I forgot about. I researched it some. I'm not sure what Tach hooked on pinball used...
And I need to upgrade the speakers....Suggestions?
Checkered flags for the speaker grill? Where can I buy them?
Quoted from jrcmlc:Ya... I know. There are quite a few here in the US, I just need to find one of you ready to change games. LOL. I caught the last one right as it sold and another that's on route is beat to shit but the guy won't sell it, just keeps running it beat to shit lol
Thats a tough one if an op wont let it shake loose!
Get a similar shape nascar kf he would be up for a trade?
Wont be very economical but i think it should get u there.
Quoted from hawkeyexx:I have the Hurst Shooter rod installed. I upgraded to LEDS and Titan Rings. Purchased new apron cards.
I think these could work
https://www.amazon.com/AK-Wall-Art-Checkered-Racing/dp/B07JQ1J4BW
Measure them out to see how big they are but this and a little double sided tape and ur done.
Quoted from trueno92:I think these could work
amazon.com link »
http://www.speakerlightkits.com/
Screenshot_20230530_095235_Chrome (resized).jpgThat's not a bad idea but his will need much love, he maintains the games poorly, to say the least.
Quoted from trueno92:Thats a tough one if an op wont let it shake loose!
Quoted from Scott8806:Thanks I got rid of All my new pinball games I like this era wayyy better I’m my opinion lol
This era is cool in that it’s very mode focused but it’s not at all linear for nascar.
If you had a new ff or gz, send it up my way!!
You should try some de games like last action hero as well. Very similar style of play. Start a mode, do this, stack it with another mode, get multiball on the stack etc.
This page was printed from https://pinside.com/pinball/forum/topic/nascargrand-prix-owner-and-fan-club/page/32 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
