New! Dark mode!
(Topic ID: 272312)
NASCAR won’t boot
By Wally69
3 months ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 3 months ago by ChrisHibler
    #1 3 months ago
    Hey gang,
    I recently bought a NASCAR at an estate sale and attempting to fix it
    Acid Slightly damaged cpu board, replaced u212 and it’s socket (below battery’s) after repairs and cleaning the board I did a continuity test on all u212 pins to where they end up , Pin 26 was open so I repaired damaged Trace with a small jumper wire
    I installed board and now it won’t boot up, the blanking LED L204 and 18v LED L202 are alternately blinking in synchronization with playfield Control lamps and I/0 board relay
    Anyone have an idea on what to check next?
    #2 3 months ago
    Check all the connections, you might have missed one or misaligned one.
    #3 3 months ago
    Did it boot before the repairs were made?
    Alkaline corrosion can drip down into u205/206 area and prevent inter board comms.
    Chris Hibler - CARGPB #31
    Http://chrishiblerpinball.com/contact
    http://www.PinWiki.com/ - The new place for pinball repair info
    #4 3 months ago
    Didn’t try to boot it till repairs were done
    No acid got around any other chips
    I just got back from swapping cpu boards from another NASCAR and the problem followed the board
    I also swapped 210 and u213 and still same
    #5 3 months ago
    I got the u212 chip from Marco, does it need to be programmed? Or is it plug and play?
    #6 3 months ago
    U212 is the RAM chip. It is plug and play. It would have been a good idea to install NVRAM instead of RAM at that time. Oh well.
    You have more corrosion somewhere that hasn’t been found yet.
    $ 5.00
    Doc's Pinball Shop
    $ 99.95
    Cabinet Parts
    Merf's Pins
    Creo Pinball
    $ 69.95
    Hookedonpinball.com
    $ 69.99
    Metal-Mods
    $ 5,899.00
    Little Shop Of Games
    $ 7,500.00
    $ 4.49
    COINTAKER.COM
    Metal-Mods
    $ 7,599.00
    $ 76.95
    $ 369.00
    $ 7.95
    Apparel - Unisex
    Pinball Wheezer
    $ 27.25
    The MOD Couple
    Mods for your pinballs
    $ 200.00
    Professor Pinball
    $ 76.95
    $ 395.00
    M&M Mods
    $ 999.00
    $ 34.95
    Playfield - Plastics
    Hookedonpinball.com
    $ 40.00
    $ 94.95
    $ 4.49
    Pinball Pro
    Metal-Mods
