Hello guys,
Got a weird issue I thought I'd throw at the wall and see what sticks as searches have net nothing.
Got a nascar with a working but shaky dmd. It was tired I suspect so I swapped in a new one and nothing. Dead. I was careful to make sure all the pins were aligned correctly, and interfaced correctly. I checked the display power supply outputs at the display and found wonky numbers, so I checked at the ps output and again found strange readings, I then checked the incoming AC and found no input for com/white. All the other voltages are correct except for the 18vdc is a volt low. Anyone care to take a stab at it? The game functions correctly except for the dmd.
Boy I'd sure appreciate it.
