(Topic ID: 150251)
10 point relay stays energized
By Spanishsilver
8 years ago
#1 8 years ago
The N relay on my Gold Strike stays energized all the time. The 10s score reel does also. Checked and disconnected all 9 10 point switches and N relay stays energized. Attached is schematic. Thanks
#2 8 years ago
Quoted from Spanishsilver:
I count ten 10-point switches.
Also check that the EOS switch on the 10-point reel is opening.
#3 8 years ago
A good suspect can be the switch behind the drop targets.
#4 8 years ago
Quoted from Cash_Riprock:
Per the schematic, none of those feed the N relay though.
#5 8 years ago
Had this same issue on a Strato Flight and it turned out to be a switch stuck closed under a plastic on the playfield.
Disconnect the playfield altogether and see what happens.
#6 8 years ago
Figured it out. The 10 point switch behind large drop bank had the thick metal blade touching the wrong side. Just overlooked it. Thanks
#7 8 years ago
oh yeah, not the drop target switches, but the switches sitting behind them that are exposed when the targets are down! Good call.
#8 8 years ago
Sounds like it was this:
https://pinside.com/pinball/forum/topic/gottlieb-em-tech-tip-mystery-stuck-switches
$ 12.00
