The A string of coils on the brown wire is dead in my Whirlwind on location (outkicker et al). Fuses are all fine, tested out of game (well F2A is fine, F4 is blowing but I’m not sure how that’s related, and it doesn’t blow during testing so I’m fine there).
-I have continuity through the brown wire to every coil from F2A
-I can’t manually fire these coils by grounding the transistors, that has no effect
-Getting scrambled garbage voltage readings at F2A and the start of the brown wire, it should be 25vdc but not sure if probing here is problematic?
-Flashers on that fuse/C side are fine.
Is this an A/C relay issue? Bridge? Or not the Auxiliary Power Board at all?
