New! Dark mode!
(Topic ID: 228530)
mysterious Gottlieb System 80 Counterforce CPU reset
By jstree
1 year ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by dothedoo
    #1 1 year ago
    Hi there!
    I bought a Project counter force, and have run into a strange set of behaviors:
    things i have done:
    new rottendog power supply grounded to speaker
    docent harness from power supply to CPU
    Repinned Connectors from CPU to DRIVER BOARD
    All fuses checked, all coil resistances measured OK
    Had bad Q relay coil, replaced with new coil.
    new Niwumpf System 80 Board
    the problem:
    The unit powers on just fine and goes into attract mode
    can cycle all coils ( Coin door stuff disconnected tho) and all lights and switches thru niwumpf. Each switch test fine, etc no noticable problems.
    Start a game and the soundboard plays the first couple sounds.
    The first time the ball touches a switch ( yes, ANY switch!!) the LED on the Niwumpf board flashes 3 times, locks up and displays a couple very bright random characters on the displays.
    confused, as the switches test fine. if it was a short/accidental contact on the switch matrix , it would be only when one switch trips.
    Im stumped with a hypothesis that fits the facts. sound board? ( why would sounds work in test but freak out CPU during game?) harness connector? (theres no common wire between all). Some kind of loss of 5V power? ( the main capacitor has been replaced on the bottom board but i think thats 12vdc anyway?)
    Im stumped... any ideas?
    #2 1 year ago
    Quoted from jstree:
    Hi there!
    things i have done:
    the problem:
    Mine does the same thing and I'm currently working with Ace on the problem. Additionally, my Niwumpf had a strange flickering issue with the lamps in attract so he sent me a replacement board hoping it would fix both problems.
    The new board corrected the lamp issue, but I still get the lockup at game start with one bright character in two displays. Unfortunately, he no longer has a Counterforce to test with, but I'm happy to do whatever testing is needed as he updates code.
    An original Gottlieb MPU with a Flipp sound board works perfectly in my game, so I doubt you have any other issues with your machine.
    #3 1 year ago
    That’s so wierd!
    I guess some of the lights flash quickly , almost too quickly... but they only flicker once. The test menus and everything else work perfectly!
    I almost wonder if the drop bank coil logic is reversed or something along those lines.. the cpu is expecting switches to be open when it activates the drop target coils instead of closed...so odd. I guess we will see what happens in the next couple weeks
    #4 1 year ago
    Gentlemen,
    I am back from time off, and have the chance in the coming days to see if I can figure this out. Let me understand what the consensus is. On game start up, the banks reset, the ball launches into the shooter lane, we get sound, but as soon as a switch is registered - the CPU crashes - is that a similar experience for both of you?
    -Ace
    #5 1 year ago
    All I know is mine locks up at the start of the game.
    From the videos I sent you (I can post them here if you want), you can see that the game start sequence is different from the original MPU. The startup sound is slower tempo and the drop target bank resets slowly and drops every other target (they should all be standing.)
    I don't need to hit a switch on mine to lock up the game, but that may be because some of the targets are dropped.
    #6 1 year ago
    I have had that happen on a Stern Split Second because of a weak C-23 on the solenoid driver board. Try a 35V - 15000uf.
    #7 1 year ago
    Sorry, I have this post mixed up with a Bally post of the same problem. I don't know if changing out the filter cap on the bottom board would help this or not. Same 35V - 15000uf cap for the Gottlieb game.
    #8 1 year ago
    I have a new cap on the transformer board. Ace has identified a bug in the software and sent me a patch. I'll try to test it today.
    Pin Monk
    $ 9.99
    Cabinet Parts
    Maple Street Sign Shop
    $ 1,000.00
    $ 11.95
    $ 999.00
    $ 175.00
    Professor Pinball
    $ 42.00
    $ 4.49
    $ 69.00
    The MOD Couple
    $ 27.99
    $ 19.95
    SilverBall Designs
    $ 86.95
    $ 3.00
    Cabinet Parts
    BK Pinball
    $ 29.99
    Full Tilt Pinball LEDs
    $ 54.99
    $ 63.00
    $ 96.95
    € 3.70
    Buthamburg
    $ 2.00
    Doc's Pinball Shop
    CzTV Mods
    $ 99.99
    $ 54.99
    $ 29.95
    Apparel - Unisex
    The GameRoom Store
    $ 100.00
    Professor Pinball
    TheDudeMods
