(Topic ID: 261584)
Mylar Replacement
By Joeynelyse
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by ForceFlow
#1 4 years ago
Question, I recently acquired an F14 Tomcat and was thinking of replacing the mylar. If I were to pull the old mylar off, do I need to remove the adhesive before laying the new mylar...or can it simply be smoothed down over the existing glue?
#2 4 years ago
There are several posts on mylar removal. There is quite a bit of risk with System 11 playfields in pulling up paint and artwork. Sometimes it's better to leave well enough alone.
#3 4 years ago
On a system 11? I would absolutely avoid doing that. The chances of losing paint are fairly high, and a near certainty on the inserts.
#4 4 years ago
Quoted from ForceFlow:
Since you mention that, please help others like me that know enough to know that I don’t know enough about Mylar on pinball machines, what machines are ok (using proper Mylar removal practices) to remove it, and what machines are not, like you mentioned above?
#5 4 years ago
Yep leaveing it alone is probably the best option. The freeze method works pretty well in most cases but still cld have issues pulling things off the playfield. Also yes u wld need all.old glue off the playfield.
#6 4 years ago
Quoted from JayDee:
Since you mention that, please help others like me that know enough to know that I don’t know enough about Mylar on pinball machines, what machines are ok (using proper Mylar removal practices) to remove it, and what machines are not like you mentioned above?
In most cases clearcoated play fields are ok to pull mylar from
#7 4 years ago
Quoted from JayDee:
WPC is usually ok. Gottlieb system 3 tends to be iffy (and is usually best to avoid).
$ 12.50
RoyGBev Pinball
$ 54.99
5,000 (Firm)
Vandalia, OH
$ 1.00
Pinball Alley
$ 44.99
Pinball Shark
$ 5.00
Metal-Mods
$ 18.00
Flashinstinct
$ 18.95
$ 69.00
Pinball Pimp
2,100
Rancho Cucamonga, CA
$ 65.00
arcade-cabinets.com
$ 19.99
Fort Lauderdale, FL
$ 39.99
Cedar Rapids, IA
$ 36.95
This page was printed from https://pinside.com/pinball/forum/topic/mylar-replacement and we tried optimising it for printing. Some page elements may have been deliberately hidden.
