Is all mylar the same? Or would you recommend one from a particular source? I have a TAF with some wear. I filled and painted the limited wear around the windows on the mansion, then covered it with mylar from Marco. The mylar seems intermittently hazy, though is not easy to see unless you are looking for it. The other mylar that the machine came with seems clearer. So just wondering if there are sources of mylar that are better than others. Thanks for your help to a newbie.
