(Topic ID: 237845)
My top 2 worst things when working on my pins
By MK6PIN
5 months ago
  • 114 posts
  • 65 Pinsiders participating
  • Latest reply 4 months ago by jfesler
  • Topic is favorited by 9 Pinsiders
    There have been 6 images uploaded to this topic. (View topic image gallery).
    There are 114 posts in this topic. You are on page 2 of 3.
    #51 5 months ago
    It seems to me that the wires that like to break the most are the ones in locations that you can barely see, can't get to without folding yourself in half, and can't fix without bumping 18 other wires with a hot soldering iron.
    #52 5 months ago
    I am the worst offender. Most recently I opened up a pin to find my dremel just sitting on the cash boxed still plugged in... I didn't even know I was missing my dremel.
    #53 5 months ago
    Quoted from WolfManCat:
    Could have been worse. Could have been your plugged in soldering iron...starting the game on fire.
    13
    #54 5 months ago
    Attaching the head and realizing you forgot to pull the power cord out first.
    #55 5 months ago
    These!
    #56 5 months ago
    Getting a cramp while working between machines
    #57 5 months ago
    Easily my favorite thread to read as of late!!!!!! Hilarious stuff (not at the time, of course). Why do we do this stuff to ourselves...the "love" of pinball!!!
    Adding another - playfield lit up in service position, note a loose wire on the GI circuit...my soldering iron already hot, I'll just resolder with game energized....game goes dark, Lloyd scolds me (as he should), and I seriously thought about taking my TZ outside and setting it on fire....doesn't really fit my thread title, as i'll never be doing that again ( happened several years ago, but a story worthy of repeating)....
    #58 5 months ago
    LMAO!!!!
    #59 5 months ago
    Buying bayonets instead of the correct 555’s or other way around :/
    Or having 2,3,4,6,7.8,9,10,11,12 .156” connectors and not the 5spot you need.
    #60 5 months ago
    Screws and nuts fall under the board on the bottom of cab or in the speaker
    #61 5 months ago
    Doing a complete teardown on a game ,taking a 1000 pictures and you need 1001 ....
    #62 5 months ago
    Quoted from guss:
    Yes, that is my number one.
    Number two = working to fix a problem for hours and finding out it is a simple fix after all. One I know about. One I have seen before.
    #63 5 months ago
    Quoted from Langless28:
    Or forgetting to cut a 6 down, file smooth. And continue.
    #64 5 months ago
    Having to replace a uncommon but necessary bolt or screw that's missing, requiring a $10 shipping charge for just that one piece. Then during a thorough cleaning of the inside of the cabinet a few weeks later, finding said part stuck inside the speaker or under the transformer panel. Grrrr!
    #65 5 months ago
    Quoted from jibmums:
    Having to replace a uncommon but necessary bolt or screw that's missing, requiring a $10 shipping charge for just that piece. Then during a thorough cleaning of the inside of the cabinet a few weeks later, finding said part stuck inside the speaker or under the transformer panel. Grrrr!
    Thisssssss
    #66 5 months ago
    When you buy a new part...
    ...and you install the new part...
    ...and it doesn’t fix the issue.
    #67 5 months ago
    playfield raised: solenoid plungers and other mechanics move freely.
    playfield lowered: geometry changes & plungers and other things move sluggishly
    raised, lowered, raised, lowered, raised, lowered, open the coin door to figure THAT out
    #68 5 months ago
    Not sure if this qualifies as “working” on your game but when moving them out of the house, back box is nice and wrapped to cabinet, take back legs off, tilt game onto it’s back, clang clang clang clang. Forgot to take out the balls. Every. Damn. Time.
    #69 5 months ago
    Having 20 uninstalled mods sitting on my workbench and never installing any of them because when the decision needs to be made between spending a couple of hours playing or a couple of hours installing, playing wins every time.
    #70 5 months ago
    And then ordering more mods the next day.
    #71 5 months ago
    Great topic and funny but true!
    Here is one of mine. Your working on an assembly, you don't seem to have a problem taking it apart but when you go to put it back together your finger reach seems much shorter and getting those screws back in with the wiring harness in the way is much harder, you try and drop screw, no problem you find it, so you try a different route, and drop screw again, but this time it rolls under the transformer panel and you have to find a piece of wire to fish it out, then you spend a few minutes planning your next attack like Wile E Coyote, only two drop screw again and again.
    Pro tip, get screw starting screw drivers and save your sanity, or in a pinch take that 14 gauge wire you used in previous step of fishing for the lost screw and wrap it around screw allowing you to guide into position more easily.
    #72 5 months ago
    One of the worst is when you're working on an EM, and you drop some minor little thing like a nut or a bulb or something... and it lands just right to slide down beside the board on the bottom of the cabinet, then roll under the board so you can't possibly reach it.
    So then you have to start thinking "Should I try to just tilt the cabinet to one side and see if I can get it to roll to the side and grab it with some pliers?"
    or "Maybe I can slide something flat under the board and push it out the other side"
    but eventually you have to take the bolts loose and move the board to get whatever little tiny thing you dropped down in there out...
    #73 5 months ago
    The other day I was ordering some stuff from Marco (which I love) and had written down everything I found on a machine that I needed to order. So while I'm doing it, I see something I hadn't thought of like, oh instruction cards and add that to the cart too. So then I go back to the machine, work on it awhile looking for other stuff I might need to order, oh, I need some of those clips (or whatever)... so I go back to add it to the cart off the website, and the cart is empty because I screwed around too long without checking out.
    Damn, now I'll have to redo it all over again. So I go reorder everything I had written down, then add the clips and checkout... then just after I press the checkout button, remember that I forgot to add those cool instruction cards (for $1.50 or whatever) back in
    #74 5 months ago
    Quoted from CNKay:
    Yup, exactly what I was saying too, lol
    #75 5 months ago
    Dropping screws etc and they go to that special place that can't be found?
    Fixing shitty repairs or dodgy hacks.
    #76 5 months ago
    Quoted from cooked71:
    Stop looking on my bench!!!
    #77 5 months ago
    Quoted from gunstarhero:
    Or....convinced you need a part to fix, order it, then find the actual problem while waiting for part to arrive. Justify purchase in your mind "I'll need it someday"...I have a good stash of that stuff..
    #78 5 months ago
    1. I will burn myself with the soldering iron every session that I use it. It’s a GUARANTEE.
    2. I will ALWAYS button the game back up without putting the balls back in.
    #79 5 months ago
    Quoted from chuckwurt:
    I got in the habit a few years back of putting removed balls in the track under the removed lockbar. They won't fall off, unless you knock them off, and there's no way to put the glass back in without moving them first.
    #80 5 months ago
    Quoted from JWJr:
    This is fantastic advice and a buddy of mine always yells at me to do this. But old habits are a bitch. Haha
    #81 5 months ago
    It is so comforting to see that I’m not the only person that does these things! This thread had me laughing all the way through!
    #82 5 months ago
    losing a C-clip. Or a JC clip...as in "Jesus Christ there goes another one!!!!"
    #83 5 months ago
    Quoted from LyonsRonnie1:
    Happens to me when I order from Comet.
    #84 5 months ago
    My top 2 worst things when working on my pins is:
    1- Might have a little drink-e-poo while tinkering with my games.
    2- Little drink-e-poo turns into a "party of 5" of drinks and before ya know it I am half cut and can't find (nor do I care) where I left that Phillips screw driver. Ah well, better have another drink, that'll make it all better.
    I AM NOT AN ALCOHOLIC, I just like to drink
    QSS
    #85 5 months ago
    Glad it's not just me. Still got a scar from a nasty burn few months ago. I'm also good at melting other things under the pf when trying to squeeze into a tight place. Fun playing the "what's that burning smell?" game when using the soldering iron. Finally order a better soldering iron, maybe that will help.
    cnkay - Brilliant idea using wire to hold screw. Going to try that next time. I've used blue tape to hold screw to screwdriver when trying to get it into a tight space. I use blue tap for everything lol. That tape trick also works for getting wedge bulbs into tricky places. One example is the bulb that's behind the bubble gum machine in TZ. It's buried under riveted plastics and not accessible under pf but you have straight access to it with pf out. Wrap the tape around the tip of the bulb to a pencil or some other kind of blunt stick. Not sure it's the best method because it takes a lot of swearing and tries to finally get it to work.
    #86 5 months ago
    I haven't burned myself in a long time. Good news with soldering irons is they are basically self-cauterizing so I don't really find iron wounds to be too troublesome.
    10
    #87 5 months ago
    From this morning...
    I replace a few rectifiers.
    I triple check my work.
    I put the board back in the game.
    I check again for any shorts.
    Moment of truth.
    I hate this part.
    I flick on the power switch.
    Nothing.
    Zero at every test point.
    Shit!
    Then I notice the power cord lying on the floor.
    #88 5 months ago
    Quoted from mrossman5:
    Comet and Titan, 100% of the time.....Terry and CT, 95%
    #89 5 months ago
    My favorite rule is "if it goes back together easily then I missed something"
    #90 5 months ago
    Quoted from simplykind:
    Keeping the balls in the trough when lifting the PF thinking they wont come crashing down this time.... then naturally they do and the balls scatter across the bottom of the cabinet and floor only to leave you one short.
    I broke the playfield glass in the game next to the one I lifted that way once.
    Aside from everything else that everyone is talking about I always seem to cut myself by trying to fit my hand further into a place that it shouldn't go
    #91 5 months ago
    Quoted from TomT:
    Classic, and so true!!!
    #92 5 months ago
    Quoted from JeffZee:
    Moment of truth.
    I hate this part.
    Nothing.
    Shit!
    I've done something similar on the older Sterns -- work on/repair a board, put it back in, power on, check voltages, etc. Everything checks out -- Great! Press the credit button. . . nothing. Open everything back up, recheck everything. . . all is good. Finally it occurs to me, because these games have no free play, credits need to be added before a game can start.
    #93 5 months ago
    Anyone mention removing that screw from a playfield plastic for a different repair, then re-tightening it... making sure it's extra tight... until you here that spine curdling "Crack!" sound. Now you have a new plastic with a crack around the screw hole.
    Or you're working underneath and you reinstall the wood screws, but you want to make sure it's good and tight. After all it is a steel ball rolling around on top, smashing into things. But that last tight turn to make it nice and really tight... Then the slip... Overtightened and now the screw hole is stripped! Should have just left it tight and been satisfied.
    #94 5 months ago
    Quoted from guss:
    Then painstakingly extending a magnetic wand under the bottom board, using the tips of your fingers to swing the magnetic end further in to try to catch the screw, only to lose control of the wand and listen to it join the screw under there in nowhere land! (Only posting for a friend)
    #95 5 months ago
    If if you don’t already know, then you’ve never put together a classic Williams or Bally pin.
    No matter how many times I tell myself not to forget the power cord.
    #96 5 months ago
    Quoted from wolverinetuner:
    I have one of my wands missing too, btw (along w my favorite flashlight, that started this whole thread)....
    Laughing too hard, as I can easily put a visual to everyone of these posts (and the aftermath)...
    #97 5 months ago
    Quoted from MK6PIN:
    Agreed-great thread. It’s so great because I’ve had at least half of these scenarios happen to me and I was definitely NOT laughing at the time.
    #98 5 months ago
    Quoted from Chisox:
    It always seems so straight ahead at first..."I'll just go in, fix this, mod that, and be done" hardly ever works out that way....
    #99 5 months ago
    Quoted from MK6PIN:
    Ain’t it the truth. I’ve ordered three times from Pinball Life in the last two weeks. Just went to bend a VUK switch on my LOTR a half hour ago and snap!
    #100 5 months ago
    Quoted from Chisox:
    Literally just opened a box of dress up stuff for my MunstersLE (lit flipper buttons, gold vacuum coin bezel kit, etc.) only to find that the bezel kit only had 1 piece in it.....no sweat, as they always make my orders right (great people), but paused and read through some of this thread again....decided wtf am I doing even thinking about opening a machine this weekend after laughing at all these stories?!....glass stays on them all this weekend, and I'm just gonna play. Don't trust myself at the moment.....
    $ 15.45
    KAHR.US Circuits
    $ 218.00
    $ 76.95
    $ 8,999.00
    Nitro Pinball Shop
    $ 8,999.00
    Classic Game Rooms
    Cabinet Parts
    Flashinstinct
    Hookedonpinball.com
    $ 14.00
    Yorktown Parts and Equip
    $ 200.00
    Professor Pinball
    Little Shop Of Games
    $ 75.00
    DBC Pinball
    $ 125.00
    Sparky Pinball
    $ 96.95
    $ 109.99
    $ 7,599.00
    Classic Game Rooms
    $ 92.95
    $ 7,999.00
    Operation Pinball
    Playfield - Plastics
    Flashinstinct
