(Topic ID: 125251)
My Tee'd Off balls were gross, so I made them nice for $1.29.
By asay
9 years ago
  • 21 posts
  • 19 Pinsiders participating
  • Latest reply 6 years ago by CaptainNeo
12
#1 9 years ago
So the balls on my Tee'd Off were pretty nasty.....
I picked up a bag of plastic practice balls at Walmart - $1.29.
I had to use a heat gun to separate the nasty balls from their plastic bases. There was still a bunch of glue on them but more heat and it peeled right off. Smelled like burnt cat shit.
Some paint came off with the glue, so the bases got a coat of metallic silver spray paint. Then I took the balls to the drill press to get some holes in them. You don't need a drill press for this, any drill/dremel or even an exacto knife would work, the hole doesn't have to look pretty since it's covered by the base. Also you may or may not need to put your balls in a vice for this step - my girlfriend was very helpful with that.
Boom. Much better.
#2 9 years ago
Nice one. I will have to do this to mine as well. Thanks for the tip.
-Kyros
#3 9 years ago
I really like your balls.
#4 9 years ago
You have the whitest balls.
LTG : )™
#5 9 years ago
Those balls look a little bigger. I should have done that when I had a Teed for a while.
#6 9 years ago
seems like an odd number of balls can look good on display
#7 9 years ago
FORE !!
well done
FORE LESS
#8 9 years ago
Nicely done! I have exactly the same issue with my balls
One question: is the base (that silver cup) of your balls wacky or does it fit the holes?
My cups are too tight to simply "cover" the bulbs, so it is very hard to take it off without taking the bulb off.
#9 9 years ago
Quoted from asay:
I bet she has them in a vice!
"Boom. Much better." LOL
#10 9 years ago
Quoted from a2h2z:
They fit in the holes very loosely, which is different from a lot of pictures I've seen. In other pictures they look tight so the balls sit much higher. I'm not sure which is "right" and why there is a difference. Also Steve Young has the bases for $2.00/ea.
#11 9 years ago
nothing worse than tight balls
#12 9 years ago
durka, durka
#13 9 years ago
I just went through this with a restore of a Teed Off. When I first started ,the only way to get the balls OFF, was to seperate the ball from the base, remove the bulb, then the base. The bulb no way would pass through the base. If you had a bulb burn out were you EXPECTED to seperate the ball from it's base to get to the bulb ? I modified some led's and sanded the base a little so now you can pull the ball and base together over the led, but the base is still snug enough to wedge on the lamp socket.
#14 9 years ago
Quoted from OCD_pinball:
I just went through this with a restore of a Teed off. When I first started ,the only way to get the balls OFF, was to seperate the ball from the base, remove the bulb, then the base. The bulb no way would pass through the base. If you had a bulb burn out were you EXPECTED to seperate the ball from it's base to get to the bulb ? I modified some led's and sanded the base a little so now you can pull the ball and base together over the led, but the base is still snug enough to wedge on the lamp socket.
Huh, interesting. And they were just #44 bulbs?
#15 9 years ago
I pay a lot more than that to get my balls serviced. Good deal.
#16 9 years ago
#18 9 years ago
Looks 100% better! How do you know what burnt cat shit smells like?
#19 9 years ago
very clean looking, nice job!
2 years later
#20 6 years ago
Just found this thread and found it funny that I replaced my golf balls in the same way, except I didn't use the tees. My originals looked horrible. The tees didn't all fit right, the balls looked like they were put on by a blind guy and the glue was everywhere. There were also 4 different kinds of bulbs lighting them. I think the bag of pratice balls cost about $1.50 from Walmart and the little black sleeves I put in the holes I drilled cost maybe $1 from the local hardware store.
teed off golf balls orig (resized).jpgteed off golf balls orig (resized).jpg
3,500
Las Vegas, NV
3,000 (OBO)
San Jose, CA
$ 1.00
Pinball Alley
3,199
Wichita, KS
3,400 (OBO)
Saint-denis-sur-richelieu, QC
This page was printed from https://pinside.com/pinball/forum/topic/my-teed-off-balls-were-gross-so-i-made-them-nice-for-129 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
