9/25/19, barcade location, continued
WCS: Replaced buy-in button with a whole new button assembly. I've been having a hard time with start (and buy-in) buttons on 90s bally williams games. I pop the switch out to replace the incandescent bulb, and I'm not able to get it back into place. It's like I'm breaking them just by taking them off? Open to suggestions. This has happened 3 or 4 times now.
Batman, Dark Knight: screwed down the center ramp a little tighter as it had began to lift. This is a game I keep playing with the ramp because if I tighten it too much, the flap starts to curl upwards, and clips the ball slightly as it goes up the ramp. So, I leave the screws a bit loose, but then they get too loose over time. What's the fix?
Batman, Dark Knight: report of left flipper being a little weird. Investigate. TODO: I probably want to rebuild the flippers. They've always seemed that they travel a bit too high, like they're pointing up at the sky.
IMDN: replaced white Titan rubber on upper left flipper with standard black one. The black one sends the ball more where you'd expect (into the drops) if holding the upper flipper as a ball travels over it.
IMDN: installed Pharaoh Blinder Kit from Mezel Mods. Wanted to test pcb lights from different vendors.
Mousin' Around: Failed installation of Soren ROM. Friend who gave me the chip didn't realize it requires two different ROMs. Will re-attempt next week.
9/26/19, office location
Tron: cleaned and replaced slingshot rubbers
Tron: right singshots not firing. Switches didn't work in switch test. Discovered diode on one of the switches had come loose on one side. Easy re-soldering job fixed the problem.
Tron: TODO order new screw for top post of right slingshot. Mine broke and there wasn't enough excess to fit a nut on, which caused the plastic to break. Currently no plastic on the right slingshot. Hurry!
Tron: TODO get a quieter disc motor. I previously tried spraying some lubrication into the motor but it didn't help. The volume is required to be really low at the office, and all you can hear is the grinding motor while you play.
TWD: cleaned. Didn't initially notice because it was in a dark corner and that game has a lot of splatter to the artwork, but wow was it dirty. Over 6k+ plays in 5 months, though I believe I had cleaned it at some point during that span.
AC/DC: cleaned and replaced slingshot rubbers
9/26/19, home
GB: Ever since having it at the office location, the Slimer motor has been grinding and squealing. (I think it's because the game never got turned off for 3 months. Since then, I've got timers set up on the sockets so the games go off at night and back on in the morning). As it does that, inserts and flashers all over the game were flickering slightly. Replaced the motor, which was a shocking $70 from Pinball Life (and $140 from Marco). Slimer moves great now, doesn't screech, and the lights don't flicker anymore.
GB: Installed 1.16 code.
