Not a lot of info on this game, and this is possibly a waste of time, but I figured I'd put some observations out there, things I noticed when shopping the game out.
-The slot machine mech is really easy to work on. Just four nuts on the bottom of the playfield and some connectors. You need to remove this to remove the ramps.
-The lid of the slot machine is kind of a pain. Once you remove the screws from the sides, you need to press out on the cover from the inside to get them to clear the spacers, then the lid comes right off.
-The roulette wheel is very easy to work on, just unscrew the handle portion and it systematically comes right out in about 4 pieces.
-There is some play in my roulette wheel. I'm thinking this is by design as I have replaced the motor and the shaft and the play still exists.
-When lock was lit, sometimes balls through the slot machine would be detected as ramp shots leading me to believe the optos that detect the ball at the ramp entrance were intermittent. I cleaned them, no change. I pulled the boards and replaced the LEDs on the board. Strange boards, both sides of the switch take the same LED. I replaced all 6 while I was in there and it hasn't missed a detect since.
-At the ball lock, the up/down post was letting multiple balls by instead of one. I did all the standard stuff, disassembled the mech, new coil sleve, I couldn't find a thing wrong with it. What fixed it was, I decreased the angle of the ramp. You have to be careful though, too steep and multiple balls make it through. Too shallow, and the balls will bounce off the post or the ball and back up the ramp.
-The diverter is just a flipper mech, easy to disassemble.
-Most of the ramps surface area is one piece. Not too bad, but what's kind of a pain is the fact that you have to remove all the protectors on all the ramps to remove it.
Again, not sure anyone will care for a while, if ever, but some things I noticed. This is by far one of the most underrated games. When it's playing correctly, on 3.0, fast, at the appropriate difficulty, this game is a BLAST.
