I recently got a Taxi and having a few problems so far.
The diagnostic wiring is not connected. Does anyone have a wiring diagram of how the three switches should be connected? I'll be getting the manual in a few days but I'd like to run some diagnostics before I order the manual.
My slingshots aren't working at all.. I've checked all the fuses. I checked each Transistor on the auxiliary power supply board. Does anyone know which transistor drives the slingshots?
The Gorbie shot doesn't fire the coil that lifts up the gate. I'm wondering if the switch underneath the playfield is bad. I can still hear a click when manually pressing the switch but it doesn't respond with a sound/action. Is there a way to test these?
Other than this, I need to rebuild the flippers. (Mainly the right flipper) Rebuild the GI on the Interconnect board. (GI looks a little dim)
Then a tear down, clean and polish. Then we'll be working 100% again. Can't wait!
