I bought my first EM 4 days ago and powered it up for the first time 2 days ago (yeah, never plugged it in when I bought it).
I think I have it figured out but wanted some knowledgeable input before I tear into it.
Symptoms: when a Special is scored 2 coils lock on in the lower cabinet and will not turn off until power cord is pulled. They are the credit knocker and the lock relay. The larger lower coil on the replay unit in the head does get activated which I think is correct.
This is where the problem is. the smaller coil on the replay unit should then be activated to release the arm connected to the larger coil which it does not do. If I manually move the plunger it will release the lever and the 2 coils in lower cabinet turn off. The plunger on this small coil moves very tightly (feels like there is a spring inside of the coil sleeve or it is just too tight). The number reel shows 2 and that has never changed, does not seem to move at all. My conclusion is that one or more parts on this replay unit are gummed up so they will not move freely. Which are the plunger on small coil, the part above and a little left of this coil, the wheel itself possibly.
One other item that is not electrical. The metal L stop brackets at the top of the head prevent the glass from falling out. I assume some sort of rubber bumper cushion should be on these to prevent glass to metal contact. I am guessing that a rubber bumper the same as on the bottom of the credit knocker is correct since the wood insert panel also uses these brackets as a stop when closed. Would like to know what was originally used.
Thanks for your time.
Ed
