Hi all,
This is my first complete restoration and I want to "stand on the shoulders of [the] giants" here on Pinside to avoid making any unnecessary mistakes. I have read multiple pinball restoration guides including Vid's and others and want to start by thanking everyone for his or her contributions that keep this hobby viable.
I apologize in advance for my long post and many dumb questions.
Ok so I completely disassembled my machine to a blank playfield, scrubbed it with Novus #1, Magic Eraser and isopropyl alcohol, and then wiped it down with Naphtha to clean off the white stuff left from the Magic Eraser. Now I'm ready to move forward with working on the playfield.
Many of the arrow inserts were raised on the "pointy" end and so I have heated them with a heat gun and removed all of the raised inserts. On further examination I can see that all of the inserts are crazed (See below)
I figure if I am going to all the trouble to touch up the playfield and recondition the machine, I should go ahead and replace all of the inserts and not just the ones that were raised. I put together a list of the inserts I need along with the part numbers - but have not been successful finding them. I would prefer to purchase them from a single vendor, but at this point would be happy to get them anywhere to finish my project. Does anyone have these available for sale?
T2 Inserts Needed:
Quantity Item Unit Cost Part # Total
1 Amber 2"x1" Arrow Insert 03-7730-8
3 Red 2"x1" Arrow Insert 03-7730-9
1 Blue 2"x1" Arrow Insert 03-7730-10
7 Green 2"x1" Arrow Insert 03-7730-11
5 Orange 2"x1" Arrow Insert 03-7730-12
2 Clear 2"x1" Arrow Insert 03-7730-13
1 Red 1.5x.75 Stippled Rectangle Insert 03-8310-9
1 Blue 1.5x.75 Stippled Rectangle Insert 03-8310-10
1 Green 1.5x.75 Stippled Rectangle Insert 03-8310-11
1 Orange 1.5x.75 Stippled Rectangle Insert 03-8310-12
1 Clear 1.5x.75 Stippled Rectangle Insert 03-8310-13
1 Red 3-9/16"x1" Crescent "Hot dog" Tr. 03-7570-9
12 Red 2 1/4x1 1/8 Rectangle 03-8188-9
3 Red 1 1/2" Arrow 03-7644-9
3 Green 1 1/2" Triangle 03-8148-11
2 Red 1 3/4" Light Hood Double Sided 03-8204-9
2 Red 1 3/4" Light Hood Single Sided 03-8205-9
1 Screened Playfield Plastics Sets (50013) 31-1-50013
12 Red 2-1/4"x1-1/8" TR. 03-8188-9
2 Red 3/4", Tr. 03-7641-9
3 Orange 3/4", TR 09-7641-12
2 Red 1", Tr. 03-7642-9
1 Orange 1", Tr. 03-7642-12
1 Clear 1", Tr. 03-7642-13
2 Red Light 1-3/4" Hood, Double-Sided Tr. 03-8204-9
2 Red 1-3/4" Hood, Single-Sided Tr. 03-8205-9
T2 Eject Shields
2 Eject Shield, TR. Red 03-7351-1-9
I purchased a decal overlay - but when it arrived I noticed that the decals seem to be pretty thick so I am wondering if it might be wise to consider using them to scan and then to create my own (thinner) waterslide decals? I also noticed that although they are not raised, the bottom two inserts are cracked around the edges. What is the best way to address this?
Vid recommended laying down a coat of clear prior to touch up in his guide. I plan to take my playfield to a local auto body shop to have them spray the 2 part clear coat on the playfield. Since it will be more than 24 hours between coats, my thought is to clean it up as much as possible, replace (reglue) the new inserts, and then take it to the body shop and ask them to spray the first (and second coats) so that I can sand it when it is dry in a few days, and then do my touch ups - add new decals - and take it back to have them spray the top coat. Did I get this right or would that not be the proper way to do this?
Next, I sanded the shooter lane to remove the dirt I was not able to clean off. This is what it looked like before:
Below is what is looks like after sanding:
And this is wet after wiping with Naphtha
Should I sand this a bit more - or just stop and paint it as Vid recommends in his guide?
If you look at the below picture - this is the other wear I found. Specifically, the ball groove in the drain lane (and through the plastic insert) and a ball divot next to the special insert under the "Lite Hurry Up" insert. If you run your finger across both you can feel the depression in the playfield.
What would be the best way to address this? Again, I am thinking about removing the insert, lightly sanding the groove and the ball divot, filling and feathering it in with Bondo, and then masking the area with frisket and touching up the paint with an airbrush. (Wondering if Bondo is the right product to use or if another product may work better?)
Finally, as pictured below, the ramps dug through the playfield paint. I am thinking about doing the same thing to correct this - Bondo, feather, and air brush (or hand brush) to touch up the paint.
I don't believe these touch ups are too difficult for a first attempt. I am most concerned about matching the florescent red lines around the inserts and would appreciate any advise from anyone who has mixed this color in the past.
Thanks in advance for all of your feedback - I really appreciate your assistance!
Post edited by Pinterest: Added T2 Terminator 2 to the title
