Quoted from jonogo:I don't get what you mean here. So I take a piece of plastic thats 2" and has a rounded corner, but how do I remove Mylar with it? Use it to "pry up" the mylar?
BTW, I just drove through London couple months back on my way to Niagara. Only drove through, since we didn't need to stop, but looked like a really nice place. Very beautiful scenery around there.
If you come by again, drop in for some beer and pinball
Use the air can (freeze spray) upside down. Lift a corner, spray it and slowly pull it up, but don't force sections that don't come up, just spray more. It won't lift smoothly, but in sections sort of, hard to explain. Spray on the mylar, and underneath the bend of where you are lifting it.
After the Mylar is off, then get a flat piece of plastic to scrape the crap off, but round the corners so they don't scrape or dig in, and instead of "scrape" per say, sort of push it along, not adding too much force to the PF. You will figure out the pressure needed. It takes some figuring out, but less force and less sharp tools are the key.
Someone posted a good vid of one of the restorers doing this, and I was surprised to see he too used a random piece of flat plastic like I do.
